Author Topic: FS: New M42 Engine Rebuild Parts  (Read 4647 times)
4v/Cyl
« on: April 25, 2012, 10:25:24 AM »
Hi Guys, i have this listed on E30tech- might be more suitable here. I am going M50 route and have all of these new parts for sale... Basically a front end of engine rebuild kit more ore less. Looking for $250 shipped
11-13-1-739-592-M17   Oil Pan Gasket, Upper, 318i/is/iC
11-12-1-721-939-M17        Cylinder Head Bolt Set
11-53-1-714-738-M9          Water Pipe Connector (also use O-Ring 11-53-1-709-157-M17)
11-53-1-717-620-M101       Water Hose, Radiator/Lower Right, 318i/is/iC (1991)
11-61-1-717-761-M17        Intake Manifold Gasket, Intake Manifold Top to Intake Manifold Bottom, E30 318i M42
11-61-1-734-684-M17       Intake Manifold Gasket, Intake Manifold to Cylinder Head (1 Per Car) 318i/is/iC (1991)
11-42-1-709-800-M17       Gasket, Oil Filter Housing to Block, E30 318i M42, 318iC; E36 318i/is/iC/ti; Z3 1.911-51-0-393-338-M52   Water Pump (uses metal impeller), 318i/is/iC (1992-98), 318ti (1995-99),
13-54-1-743-261-M17      Gasket, Throttle Body to Intake Manifold, E30 318is/iC/iM42; E36 318i/is/iCM42/tiM42
13-41-1-721-972-M21       Air Hose, from Air/Water Hose to Idle Valve, E30 318i M42, 318iC
13-41-1-721-909-M9       Air Hose, from Air/Water Hose, E30 318i M42, 318iC
13-41-1-721-971-M101     Air Hose from Idle Valve, E30 318i M42, 318iC
11-31-1-247-160-M48   Timing Chain, 318i/is/iC (1991)
11-31-1-247-470-M9   Timing Chain Rail, 318i/is/iC (1991)
11-14-1-721-802-M30   Gasket Set, Lower Front Chain Case Cover, 318i/is/iC (1991)
11-14-1-721-919-M17   Gasket Set, Upper Front Chain Case Cover, 318i/is/iC (1991)
11-14-1-247-849-M17   Gasket, Top of Lower Chain
11-14-1-734-422-M30   Gasket for Lower Chain Case to Engine Block, 318i/is/iC (1991)
11-31-1-743-187-M40   Tensioner
keflaman
  • -Receive: 35
4v/Cyl
« Reply #2 on: April 26, 2012, 08:09:40 AM »
^ nice one Kman...
Anyone? you know there might be more parts in this box than are listed;)
zacrl1230
« Reply #3 on: April 27, 2012, 11:48:13 PM »
pm'd
WTB:318 \'vert
WTB:SIR tools
WTB:junk
5m1dy
« Reply #4 on: April 29, 2012, 03:21:08 AM »
Looks awesome, would you be willing to ship to Australia?
4v/Cyl
« Reply #5 on: April 29, 2012, 11:25:55 AM »
5m1dy, i will if you will pay the actual shipping costs...
keflaman
  • -Receive: 35
« Reply #6 on: April 29, 2012, 01:24:11 PM »
PM coming your way.
4v/Cyl
« Reply #7 on: May 03, 2012, 10:20:34 AM »
Sold
