Author Topic: Inexpensive Tail Light Seals  (Read 5695 times)
keflaman
  • -Receive: 35
« on: April 19, 2012, 01:58:23 PM »
I usually like to replace parts with OEM or better items, but sometimes it's awfully hard to shell out over $50 for two pieces of rubber that aren't even seen. I was walking the aisles of Lowes and spotted a box of weather stripping and liked what I saw. It seemed to be thick and dense enough to work, so I picked up a box.
It's pliable enough to work around the curves of the tail light opening without bunching up and I like the multi-ribbed construction. I installed the tail lights without the original seals and sprayed the trunk and tail light area liberally with water. No leaks then and no leaks this morning after a full day and night of rain.
I think I paid less than $18.00, so if it doesn't work I'm not out much and it's certainly better than the flat, hard seals I removed! :p
« Last Edit: October 13, 2013, 10:19:08 AM by keflaman »
tfrain
« Reply #1 on: April 19, 2012, 03:02:53 PM »
sweet!  and good idea.  Can I have the extra leftovers?!  ha ha ha!
I have same issue - I was just going to use black silicone like someone else did, but I am loathe to silicon anything on a car.  But don't want to spend the money on the originals - same as you.
carlos318is
« Reply #2 on: April 21, 2012, 02:42:28 PM »
Good idea mate I will have a look out for the same sort of thing in the UK
« Reply #3 on: April 24, 2012, 03:25:47 PM »
Nice work! I will keep this in mind for when I replace my seals too. I assume that it is adhesive-backed so you can stick it right on?
Did you do anything special where the two ends meet?
keflaman
  • -Receive: 35
« Reply #4 on: April 24, 2012, 08:39:23 PM »
Quote from: bmwman91;112111
It has a very good adhesive backing. I cleaned the surfaces of any dirt and then wiped the area down with wax and grease remover. I started at the 6 O'clock position and worked my way around to the lower, right quadrant. At that point I figured out how much more I would need to finish up and I measured about 1/4" past where the two ends would meet. The 1/4" extra was to force the two ends to compress together for a water tight seal.
When finished I was left with about a yard (one meter) of material. It's very good quality and I'm sure there will be something along the way I can use the leftovers for.
« Last Edit: August 15, 2012, 05:45:18 AM by keflaman »
tfrain
« Reply #5 on: April 25, 2012, 08:59:38 AM »
I found some of this stuff at a local hardware store for 9 bucks.  Amazon has it as well.  Going to try it as soon as I get some time.
tfrain
« Reply #6 on: August 14, 2012, 01:44:56 PM »
I finally got around to doing this this weekend.  Worked great!
keflaman
  • -Receive: 35
« Reply #7 on: August 14, 2012, 07:16:40 PM »
That's nice to hear!
I was still having a water intrusion from somewhere along the trunk seal. I repositioned it, adjusted the trunk lid, re-crimped the seal where it sits on the pinch weld...nothin!
I don't know why I didn't think to check the seals under the spoiler. Guess what? The seals were good, but four out of the six plastic mounting nuts were missing.
Doh!
tfrain
« Reply #8 on: August 14, 2012, 11:14:12 PM »
I washed the car after doing this (as I'm selling it) but I didn't really flood test it anyworse than that.  I did notice that I'm missing at least one spoiler nut....hmmmm...perhaps I should just lay the hose on it and test after replacing that nut just to double check.  I may be missing more nuts - will have to look....NUTS!
