Author Topic: Blower Control Switch???  (Read 6339 times)
anthonymax007
« on: April 11, 2012, 08:24:56 PM »
Hi everyone,
I'm not able to get the fan working for the ac/heat in my car. All the fan speeds were working a few days ago and the A/C was cool. Yesterday the fan wouldn't even turn on, and the blue A/C light wasn't coming on either. I replaced the resistor last fall, and everything was working fine until yesterday. At first I thought there might be something wrong with the blower control switch (part #61311381201) but the A/C light turning on is making me think that it could be something with the wiring behind the panels???? Anyone have any suggestions?
« Last Edit: April 25, 2012, 05:07:48 PM by anthonymax007 »
« Reply #1 on: April 12, 2012, 05:19:29 PM »
You can test the switch pretty easily, with a continuity tester.  I think it's in the Bentley and the BMW ETM.  From my experience it's usually the control bits rather than switchgear and/or wiring.
My A/C has never worked, but from what I understand there's the aux fan resistor itself.  If that's burned out, the can won't be switched on at low speed by the A/C and the system won't start.  There's also a diode in the fuse box that can prevent the aux fan from switching on.
So I'd test the aux fan with a jumper at the fanstat on the radiator.
anthonymax007
« Reply #2 on: April 13, 2012, 02:37:28 AM »
Hmmmm...I'm not familiar with where that is. Do you have a picture that I can use for reference?
« Reply #3 on: April 13, 2012, 04:14:28 PM »
It's mounted to the frame of the front fan.  Look through the grille on the left side, there's a little tubular ceramic metal bit wired inline and mounted to the fan's frame.
http://e30.bmwdiy.info/aux-fan-resistor/index.html
anthonymax007
« Reply #4 on: April 14, 2012, 06:56:50 AM »
Gotcha. Thanks for the link, I'll take a look at it today!!
anthonymax007
« Reply #5 on: April 23, 2012, 10:09:25 PM »
Well, it's not the switch. Maybe a fuse is blown? I tested them earlier, but it's always possible I missed one. Any idea which one it could be?
Nick_318is
  • -Receive: 11
« Reply #6 on: April 25, 2012, 10:09:23 AM »
Does the fan speed selector work at any speed with or without it on?  If it only blows on 4 you need a new resistor board.
The part from pelican parts
It's easy to change, here is a walk through from e30 tech.
How to Fix: Heater blower only works on high (4) speed [with new pictures]
anthonymax007
« Reply #7 on: April 25, 2012, 01:25:45 PM »
I doubt it's the resistor. I replaced it this last fall, and the fan is not working at any speed. I'm starting to suspect a blown fuse. Any idea which fuse controls the fan?
318kid
« Reply #8 on: May 03, 2012, 09:03:09 PM »
Fuse should be 20. I pulled fuzes today too, except it didn't fix my problem. My motor stopped working and then intermittently worked for a few days (lower air output) and then it stopped all together. I'm just waiting till I get te time to swap dashes to run that problem down too, but the Texas heat sure is getting to me!
« Last Edit: May 03, 2012, 09:09:20 PM by 318kid »
anthonymax007
« Reply #9 on: May 08, 2012, 01:00:09 PM »
Thanks for the info 318kid. I replaced the #20 fuse and it seems to have fixed the problem. Hopefully that's all that needed to be done!
