Hey guys cleaning out some stuff I'm sick of looking at.
Also, pretty much set on selling the 318is.
(pics coming)
1991 Alpine 318is, has salvage title out of Oregon.
Engine:
Fresh overhaul, everything marked new has less than 300 miles on it
New cam timing gears and crank gear
New head gasket with good rebuilt head
Pink 21# injectors
Ebay Chip
New E34 Motor Mounts
New O2 sensor
New radiator w/ elec fan and switch
EJ Knight (raceskids) skid plate
Trans:
New mounts
New guibo
MZ4 Shift Lever and weighted OEM shift knob
Suspension:
Ireland Stage 3 spring with 1 coil cut out of front coil, sits nice
Bilstein Sport Struts with <20k miles
General tires, siped with tons of tread
Interior:
Swapped to black leather sport interior, ok driver's seat.
I'm looking to get
$2500 for the car. Everything below is included with the car.
I've got two M42 cylinder heads. Visibly, they look good, no obvious cracks , check out flat with a straight edge. Both come with ledgers, one comes with cams but the #4 journals are scored pretty bad.
$100 each, firm.
M42 Valve Cover
$25
M20 solid mass flywheel w/ newer Bosch reman starter.
$80
Battery cover caddy thing
$10
Blue Indigo Cloth rear seat, passenger sport seat.
$50
Splash Shield good shape no broken tabs
$20
Bando belts
$10
Link to imageshack due to laziness.
http://imageshack.us/g/713/img20120331122902.jpg/Local pickup only. Thanks
