Did you check the upper oil pan bolts?!? Don't drive the car if you haven't checked them! The upper pan holds the gasket...and the main oil passage is cast into it, off the oil pump. Problem is, the little bolts can loosen up over time. If that happens, the upper pan drops slightly, the gasket slips out inside the block and you lose oil pressure (since it's now just pumping oil back into the crankcase). Drain the oil, drop the pan, check the upper bolts that you can see. The front ones are the critical ones.
Some of us have even found them in the oil pan. My pickup had a mark from a bolt, but the bolts themselves were tight. They're small bolts so don't overtighten them...I used a bit of blue locktite and tightened them to maybe 20 ft-lb? Not tight at all. They're still holding the last time I checked.
