Author Topic: Stalling at startup(video)  (Read 3296 times)
318bud
« on: March 22, 2012, 07:31:45 AM »
My car has always done this.
I have an e36 and some days is worse than others. It wont stall if im giving it gas, but when i stop revving it will stall(in video).
Its fine once i start driving and revving it up, but will sometimes randomly stall at a light
It was pretty bad today, so i decided to make a video and ask you guys
I already replaced MAF and boot
Going to try fuel injector cleaner
seafoam?
o2 or crank sensor?
what do you guys think?
« Last Edit: March 22, 2012, 07:34:18 AM by 318bud »
Geoff
« Reply #1 on: March 22, 2012, 08:00:45 AM »
I'd find out what codes its throwing, for starters.    mechanically speaking,  when was the last time the fuel filter was changed?
        Geoff
318bud
« Reply #2 on: March 22, 2012, 08:09:47 AM »
stomp test says no codes
shop hooked up scanner and told me same thing
fuel filter and pump were changed about 2 years ago
colin86325
« Reply #3 on: March 22, 2012, 10:21:18 AM »
Sounds like a vaccum leak in a hose or the intake manifold gasket.
318bud
« Reply #4 on: March 22, 2012, 11:47:25 AM »
the hoses all look fine. Havnt thought of intake manifold gasket. Im gonna check that out
ose30
« Reply #5 on: March 23, 2012, 01:27:09 AM »
Vacuum leak or bad fuel pressure regulator.
5m1dy
« Reply #6 on: March 23, 2012, 09:25:30 AM »
Check the two pipes on the Idle Air Control Valve. Mine's been known to pop off, which would cause something like this to happen, where it can run for a bit, then dies etc. Its just under the intake pipes, near the firewall. If the pipe disconnects, it won't throw a code , as the resistance/functioning of the unit itself still works.
willworkfore30s
« Reply #7 on: March 23, 2012, 03:44:19 PM »
My e30 has almost identical symptoms.  I just recently did the mess under the intake and I don't remember it doing it before that but I didn't drive it very much before that either so IDK but I will look into the vacuum leak thing.
