Author Topic: E36 dme "ecu"  (Read 11018 times)
danlolasdad
E36 dme "ecu"
« on: March 19, 2012, 05:14:32 PM »
Hi guys i was stripping my e36 318is breaker today to do an ITB mockup ill get this car running with my setup before transferring to my touring project car. When it comes to engine management im a dab hand with VEMS ive used it many times over the years and had great success but im trying new things and i see lots of you chip and remap your DME forgive me if i use the term ECU it comes more naturally to me even though its the same thing. Question can this DME
Be remapped to suite my M42 ill be deleting all the poo valves etc ill be running,water temp sensor,air flow meter, tps, crank sens and maybe cam sensor if i still need it.injectors, coils and o2 sensor. can i use it like a standalone or has it limitations. my m42 will be stock with itbs fitted and de cat probably different injectors uprated fuel pump and adj fuel pressure regulator.
mockup pics
MLM
  • -Receive: 10
    • My M42 ITB Project
E36 dme "ecu"
« Reply #1 on: March 19, 2012, 05:53:03 PM »
I dont think you can treat it like a standalone, as in to reasign outputs to drive different things. Most people have the chip retuned for fuel and ignition and maybe some other routines but all the sensors still exist anp play a part.
bmwconnect
E36 dme "ecu"
« Reply #2 on: March 19, 2012, 06:04:46 PM »
Anything can be done with the stock DME including boost ... it's a matter of disassemble of the machine code and learning routines
cheers
Midnight YouTube Channel
danlolasdad
E36 dme "ecu"
« Reply #3 on: March 19, 2012, 06:37:09 PM »
Quote from: bmwconnect;111243
cheers
BMWCONNECT please explain some more thanks. I was trying to search this earlier and my searches seemed fruitless then i remembered "ostrich" :o so typed it as a search term and there you were. can i calibrate a toyota tps to work with this setup or will i have to fit the bmw tps to my toyota itbs. this is what i have lying about as im more toyota proficient. all my vems installs were on toyotas. thanks in advance for any advise im researching all posibilities re EMS for my E36 touring project.
 http://www.m42club.com/forums/showthread.php?t=13282&highlight=ostrich
bmwconnect
E36 dme "ecu"
« Reply #4 on: March 19, 2012, 06:58:29 PM »
Quote from: danlolasdad;111244
Do you have a data sheet on the Toyota TPS?  I would start  with that first and compare with a BMW TPS . There is most certainly TPS voltage related maps in that DME. Cheers
E36 dme "ecu"
« Reply #5 on: March 19, 2012, 07:36:42 PM »
Might have some EWS on that unit.  I'm not sure, can't find out much about it.
bmwconnect
E36 dme "ecu"
« Reply #6 on: March 19, 2012, 07:46:47 PM »
Quote from: DesktopDave;111248
DME 950 should be a non ews
Esprit Aviation
E36 dme "ecu"
« Reply #7 on: April 01, 2012, 05:55:09 PM »
Can you please tell us specifically what the Toyota ITB's are from and what you have to do to mount them? I believe there would be a great deal of interest in these.
Thanks, Lee
danlolasdad
E36 dme "ecu"
« Reply #8 on: April 02, 2012, 07:15:45 PM »
These ITB'S are from a toyota AE111 4age blacktop 20v also found in a smaller size on the AE101 4age silvertop 20v i have plenty of these from building toyotas over the years ill draw up an adapter plate on autocad once i get a chance ill design it to accept the stock toyota inlet manifold and not the itbs direct so there will be no need for custom fuel rail. ill be doing a thread on my e36 316se touring build im still gathering parts and bimmer knowledge:-O ill also be utilising my toyota know how to come up with new ideas and solutions to some bmw problems as i progress since im a great problem solver :-)
« Last Edit: April 03, 2012, 06:41:26 PM by danlolasdad »
Esprit Aviation
E36 dme "ecu"
« Reply #9 on: April 03, 2012, 03:13:24 PM »
Great idea!
Is the gasket in the second pic from between the head and lower intake on the
M42?
It would be ideal to use a map sensor based system to do away with the airflow meter. You may be able to maximize flow that way.
Do you have any of the Toyota ITB's available for purchase and do you have any plans to make up several adapter plates for sale?
Lastly, will the ITB's bolt up to any other Toyota engine?
Thanks, and best of luck. You are certainly on the right track!
Lee
danlolasdad
E36 dme "ecu"
« Reply #10 on: April 03, 2012, 07:07:01 PM »
Quote from: Esprit Aviation;111626
Great idea!
M42?
Lee
ill get better value from the machine if i order in quantity so if the prototype is a success then yes ill make it available. there are adapters available to fit these itbs to the 4age 16v and to the 1uzfe(lexus v8) and probably to several more im sure. if your based in the usa there are toyota itbs aplenty stateside. i will run map sensor its what im used to doing or alpha n ill probably stick with vems as engine management. yes the gasket is for between the lower manifold and the cylinder head its a pity the m42 inlet ports are so big narrower inlet ports are proven to help gain torque.
https://technotoytuning.com/toyota/16v4age/4ag-individual-throttle-body-adapter
https://technotoytuning.com/toyota/20v4age/4ag-20v-velocity-stacks
https://technotoytuning.com/toyota/20v4age/4ag-splash-guard
something i mocked up once ;-) it ended up N/A
