Stock 2002 flywheels are about 15-16lbs vs almost 30?lbs for the dual mass.
2002 flywheels can be taken down safely to 11-12lbs. We're using a 215mm clutch assy, I trust the way they Plate and Cover are fastened together more than I do the 228mm, and the 215mm assy is fine below 200hp and 8Krpm
The recipe is fairly simple:
Use shorter flywheel bolts..from 2002 or whatever.
A few of the mainseal cover bolts will touch the back of the flywheel. I've seen in other threads where folks have used a spacer under the flywheel, but I think it is smarter to simply swap them to countersink style heads (easy, just remove, countersink, and replace one at a time without removing the cover.
The slave cylinder is indeed much more compressed with the 2002stuff but it shouldn't cause any change other than a little bit more preload on the throwout bearing. It wouldn't hurt anything to cut a bit off the rod. Even if you don't, it looks to me like there is still enough throwout travel left to run the clutch disc into its rivets..but obviously adding a spacer under the flywheel would take some of that wear allowance.
Anyway, you could also easily surface the 2002 flywheel a bunch to put the throwout back closer to its stock relaxed location. If you have time&tools to work on the flywheel you could also just cut clearance for those seal cover bolts
the 2002 ring gear is about a tenth of an inch bigger in diameter so you need to ovalize the mounting holes on the starter (including the one for the locating pin) so that the starter can pulled away about .050" as the bolts are tightened.
Not sure if I had to do it?, but I also hit the inside of the bell housing with a die grinder to make sure the starter had enough room to move out.
Thats it. 15lbs off the flywheel is a very significant difference. Obviously it requires less energy to spin the motor up each time as you row up through the box which is great, but even better is the free-reving quickness..handy when blipping up to match revs during downshifts.
-Mike
PS I think we'll have the motor and tranny out again this weekend so I'll shoot a couple pics then.
