Author Topic: E30 M42 Cold Start - raised idle  (Read 3633 times)
JHZR2
« on: March 11, 2012, 08:54:44 PM »
Does anyone with an E30 M42 engine get a raised idle at cold start?
Some of my cars do 1000-1500 rpm for a short while when it is a very cold start.  My 318i always starts and runs at the same idle speed it does any other time.  It is a bit low - 550 or so on the tach, but it is consistent and smooth.
Does anyone have a fast idle at cold start that comes down to normal after?
carguy101
« Reply #1 on: March 20, 2012, 07:55:49 AM »
My guess is it is running rich and trying to pump the oil through the engine before driving. most cars run rich on start up but this is my guess.
Gabs
« Reply #2 on: March 20, 2012, 08:19:37 AM »
Living in Canada I drove my car through a couple winters and experienced the idle around 1300 on cold starts and once warm it usually settled down around 800. It doesn't sound that abnormal, but I would clean the Idle Control Valve just for good measure, it may be sticky.
This little guy.
Geoff
« Reply #3 on: March 20, 2012, 12:15:05 PM »
I'm thinking a slightly raised idle in cold weather is normal also.  Mine will run at around 950 / 1000  rpm on a very cold morning,  coming down to a normal 750 or so after 3 or 4 minutes.
                                             Geoff
Gabs
« Reply #4 on: March 21, 2012, 08:16:21 AM »
For reference how cold of a morning are you referring to Geoff? My very cold morning are around -25f give or take.
Geoff
« Reply #5 on: March 21, 2012, 02:44:50 PM »
cold around here is anything below freezing, 32F   or so.    anything above that,  and the idle settles at 750rpms right away.
        Geoff
