Author Topic: M42 turbo  (Read 53267 times)
fumstoo
M42 turbo
« Reply #75 on: February 15, 2013, 04:39:33 PM »
So i think ive come to the conclusion that i need a 323i TOB. Im going to gather a mixture of TOBs to test when i get back with the car. I miss driving it.. :( The 535i is a total slug...
wouterterstege
M42 turbo
« Reply #76 on: March 04, 2013, 04:18:12 AM »
What kind of wheel do you have?
fumstoo
M42 turbo
« Reply #77 on: March 08, 2013, 05:27:00 PM »
The wheels on the e30 are xxr 527
fumstoo
Re: M42 turbo
« Reply #78 on: April 22, 2013, 03:18:30 PM »
GTX2867R. I think thats the final decision. Should spool pretty quick, be good for 20+psi and hold strong till redline.
Emailed VAC about some cams. Ill be back in Wy in may so ill be able to get the trans issue sorted.
Oh, and ive been spending a lot of time researching tuning. So when I get back im going to tune the car for 15psi on the current setup
wazzu70
  • Nasty Nick
  • -Receive: 18
Re: M42 turbo
« Reply #79 on: April 22, 2013, 06:32:26 PM »
Thats a decent choice. The BW EFR is still a much better turbo though IMO. The Garrett uses 90s era turbine design.
You can't go wrong with the Garrett though, but you could go "righter" with an EFR 6258 or 6758.
-Nick
91 E30 M42 with VEMS
fumstoo
Re: M42 turbo
« Reply #80 on: April 22, 2013, 07:31:52 PM »
The only issue is my manifold is an external gate. If i capped it off i feel like that would affect the flow of the gases. Am I wrong?
wazzu70
  • Nasty Nick
  • -Receive: 18
Re: M42 turbo
« Reply #81 on: April 22, 2013, 09:12:49 PM »
It would have a slight impact on the manifold flow.
Then again you can always disable the IWG on the Borg :)
« Last Edit: April 22, 2013, 11:27:43 PM by wazzu70 »
-Nick
fumstoo
Re: M42 turbo
« Reply #82 on: April 22, 2013, 09:46:53 PM »
Can you explain how thats done? Or link me? Ive researched it a bit but I cant find one way that seems legit. Damn the internet and all of the bad information on it.
wazzu70
  • Nasty Nick
  • -Receive: 18
Re: M42 turbo
« Reply #83 on: April 23, 2013, 12:22:59 AM »
You just lock the actuator arm. Basically lock the flap shut.
That or sell your external gate and put the money toward the new turbo (and WG cap).
Since you already have an external gate, you may just want to go Garrett. Its unfortunate BW does not offer an external gate housing in T25 flange.
-Nick
fumstoo
Re: M42 turbo
« Reply #84 on: April 24, 2013, 10:46:58 AM »
That turbo wont hold if i rev till 8k. Still havent heard back from vac about the cams though.. So as soon as i figure that out i can pick a turbo..
Do you think factory lifters are good for 8k? Or should I go for vw lifters?
So ive done some reading and i think hydraulic lifters should be good for 8k. The vw lifters are lighter but im unsure which of the two are stronger.
« Last Edit: April 25, 2013, 04:22:07 PM by fumstoo »
wazzu70
  • Nasty Nick
  • -Receive: 18
Re: M42 turbo
« Reply #85 on: April 26, 2013, 11:43:58 AM »
I dont have a difinitive answer on the lifters, but I am working on that now. MM uses the early M50tu lifters because they have a stiffer internal spring on engines with a 7700 rev limit. To go higher you most likely need solid lifters.
On the VW lifters I would test the spring rate of the internal spring. This is more important than weight. A lightweight assembly is no good if it collapses under high revs.
-Nick
fumstoo
Re: M42 turbo
« Reply #86 on: June 01, 2013, 07:19:17 AM »
So i replaced my pivot pin and swapped my spacer from the front to the back of the flywheel. Its hard to tell the difference but i hope it fixed the issue.. I did go and drive the car a little bit last night. Tried out the new lsd too. couple donuts and burnouts  :D Clutch seems stiffer. I wasnt worried until later in the night when it wouldnt go into gear. had to shut the car off and put it in first.
fumstoo
Re: M42 turbo
« Reply #87 on: June 22, 2013, 09:39:28 AM »
did a burnout in an empty parking lot yesterday and got a careless driving ticket  >:( but the cars running fine and it was a smokey burn out  :)
fumstoo
Re: M42 turbo
« Reply #88 on: June 29, 2013, 03:02:07 PM »
It looks like I never stated what was causing my trans issues. I put the clutch in backwards............  :-[
Now that thats settled. Tested some tires today.
275/40/17
and 245/40/17
If i run the 275s i need to pull more and stiffer springs. The 245s will probably need to be dropped a little more.
E36-italia
  • -Receive: 6
    • Motorsport-Media-Design.com
Re: M42 turbo
« Reply #89 on: July 02, 2013, 11:35:53 AM »
and such small brakes behind the spokes.. brrr ;-)
