Author Topic: M42 turbo  (Read 53365 times)
fumstoo
M42 turbo
« on: March 04, 2012, 03:02:10 PM »
So i bought the motor out of the graffiti e30 and its on its way into my car. Trying to talk as little as possible and post as many pictures as i can.
Block
Factory crank (balanced out polished)
Arrow Precision H beam rods with ARP Hardware (all balanced)
Custom pistons 85mm dia (drop com down to 8.5:1)
MLS Head Gasket (.070)
ARP head studs
Final Compression 8.5:1
Head
M42 Titanium Valve Retainers (7mm)
One piece stainless steel valves (+1mm Oversize)
High Performance Larger valve guides (+1 outside dia and inside dia)
VAC High Performance BMW Valve Springs(H-11 Alloy)
High Performance Shims
Hardened Valve Locks
Factory Lifters
Factory cams
« Last Edit: September 06, 2013, 11:07:43 AM by fumstoo »
chance
M42 turbo
« Reply #1 on: March 07, 2012, 06:29:55 AM »
Wow! That's some nice work being done. Can't wait to see it together
keflaman
  • -Receive: 35
M42 turbo
« Reply #2 on: March 07, 2012, 07:32:15 AM »
A room stockpiled full of unopened boxes excites me.:D
fumstoo
M42 turbo
« Reply #3 on: March 14, 2012, 09:05:57 PM »
Clutch and fw are here!! No pilot bearing so im overnighting one.
old
new
whole assembly weights 26.4lbs
chance
M42 turbo
« Reply #4 on: March 14, 2012, 10:23:51 PM »
Nice!
The silicon boot for the throttle body. Where did you get it from?
fumstoo
M42 turbo
« Reply #5 on: March 15, 2012, 06:29:46 AM »
chance
M42 turbo
« Reply #6 on: March 15, 2012, 11:48:42 AM »
Dang they have lots of nice stuff.
You wouldn't happen to remember the diameter of the throttle body side of the silicon hose do you?
Thanks for your help
fumstoo
M42 turbo
« Reply #7 on: March 15, 2012, 12:36:52 PM »
I dont but im sure i can figure it out. ill let you know
chance
M42 turbo
« Reply #8 on: March 15, 2012, 10:22:40 PM »
Quote from: fumstoo;111102
excellent. If not, I might be able to to wrap a wire around the throttle body and measure it, then find a diameter of a circle with the same measurement for the circumference.
nuvolarossa
M42 turbo
« Reply #9 on: March 16, 2012, 12:49:05 PM »
Quote from: chance;111117
By memory it should be around 3.5", but don't trust me, measure it!  :)
fumstoo
M42 turbo
« Reply #10 on: March 21, 2012, 07:03:32 AM »
Married the g260. I will be trying to do a write up for the m42/g260.
Gauge came in yesterday! Justrack sells these on e30tech. Amazing work that man does.
benz-tech
M42 turbo
« Reply #11 on: March 22, 2012, 10:23:48 PM »
oh that is soo sweet. how much if you don't mind my asking?
fumstoo
M42 turbo
« Reply #12 on: March 23, 2012, 12:29:54 PM »
fumstoo
M42 turbo
« Reply #13 on: March 25, 2012, 10:05:46 PM »
Some progress
A few to show how it sits with the 240 tranny mount. not sure how i want to modify this one to work or if im just going to build a new one. when i remember to bring my camera with me ill get some good pictures of how the linkage sits. Its about an inch too long and shifted to the right about 3 inches.
And because i got excited and took a bunch of pictures of my car
fumstoo
M42 turbo
« Reply #14 on: April 24, 2012, 06:47:39 PM »
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
not sure about how the wheels are going to fit..
