Bought a 1991 318i with 167k. PO had it for five years and seems like he did maintenance in the vein of 'wait until it makes a noise'. He did a good job of keeping up with things, but didn't do much in the way of preventive maintenance, e.g., no work on the timing system.
Per PO, here are the thing that have been done in the past two years: new driveline with new guibo, driveshaft, mounts, bushings, and diff (open, sadly), new shifter from a z3 with all new bushings, new struts front and rear (no performance upgrade here, just OEM), new water pump, radiator, fan, tstat, temp switch, alternator. Car has very clean black vinyl comfort interior and crack free dash.
I'm wanting a reliable dd, here. I will invest in maintenance and wear items that will keep the car running well for me, but don't really care about performance upgrades at this time, with a few exceptions. What I want to know is, what things need to be done?
Here's my list of maintenance/mods, in roughly descending order of importance:
1. replace blower motor (broken currently)
2. replace t chain tensioner
3. replace fluids/filters
4. replace sealed beams with H1/H4
5. replace odometer gears (stopped @ 164k)
6. possibly mess under intake? (total n00b)
7. one day 4.10 lsd
8. once car is sorted mechanically I'd like to source a cardinal sport interior, but that's just cosmetic and way down the list
This is where I run out of ideas. Do I need to take the valve cover off to check timing sprockets? When there should I replace valve cover gasket?
Basically at this point the engine idles quiet, runs smooth, pulls strong, and doesn't leak. The cooling system was the only thing that came on the mechanic's radar during ppi; he replaced the temp switch and flushed the system and it's fine now. Aside from the things above, what should I do to make sure this engine serves me well? Are there any other wear items that should be fixed at about this mileage?
