I have experienced the pilot bearing staying on the shaft, not on e-30 tho.
Once it was a really old car that had never been apart, and the pilot bearing was rusted to the input shaft. Another time, the bearing had gone bad and heat fused the bearing onto the shaft. If your bearing is stiff or frozen I would suspect that. If the bearing still turns easily, I am not sure what could cause that. However, sometimes the bearing is a bitch to get out, and you have that problem beat:rolleyes:
Geoff
