Author Topic: Parts from Turbo Race Car shop  (Read 4530 times)
rob_e30
« on: February 11, 2012, 03:21:46 PM »
Everything below comes out of my garage or our race trailer.  These are spares or parts for future projects that we won’t be using.  Many are new or like new, most are cleaned, some need to be taken apart for components and cleaned.  All sales are As-Is, local pickup preferred but we might ship at buyers expense.  Some of the larger, heavier parts will be expensive to ship.  Nothing comes with a warranty, guarantee, or promise of completeness or suitability for any specific application.  Please contact before purchasing if you have any questions.
http://photobucket.com/hqautosportspares
M42 Cylinder Head, Complete, SOLD
JB Aluminum racing flywheel 9lbs.!  SOLD
Water Pump Kit: SOLD
NIB Timing Chain Tensioner SOLD
Front Timing Case Seal NIB $10
E36 M42 Wire Harness - $125 Includes relays
M42 Intake Plenum (Upper half only) – Half Price!  $25 plus shipping
M42 Dampner, Crank Pulleys - $30
M42 Exhaust Header    SOLD
Idle Air Control Valve (2 available) $50 each
Power Steering Pump (Dirty) $80
Cam trays and buckets (2 complete sets) $25 per set
Head for spare parts.  #3 piston dome destroyed.  CAM trays, springs, and remaining valves are good.  $50
Polished valve cover, could use new polish but should clean up nicely.  $80
M42 High performance short block.  Engine was running when disassembled.  Intended for high rev, normally aspirated street/HPDE application.  Knife edged/lightened crank, custom rods.  Believe to be $1.8+L motor based on our bore and stoke measurements.  There also a photo of a crank for reference purposes.  This bottom end is assembled and ready to go.  Includes new water pipe.  $500
 PENDING SALE
Fan, water pump, thermostat and pulley.  Came off the High Performance engine.  Steel impeller water pump. $50
Painted upper and lower timing case cover and thermostat housing.  Came off the High Performance short block engine. $100
Inner timing case with crank bolt and hall effect crank position sensor.  Came off the High Performance short block engine.  This is an aftermarket dampner, with the sensor (vendor not known).  Uncertain if the timing case was modified to fit only this sensor or if a stock sensor will still fit.  This is a great upgrade if running an aftermarket ECU. $250
Black Powder Coated Intake and Valve Cover Kit.  Includes custom intake adapter for an M20 throttle body.  If you don’t want the adapter, let us know and we may separate but they were bolted together when we took the picture.  All were professionally crinkle powder coated, but the valve cover would benefit from touch up with black engine spray paint. $125
Alternator, bracket, and dip stick tube.  $150.
#1 Upper and lower oil pan and pickup. SOLD
Oil Cap & Oil Filter Housing - $80
#2 Upper and lower oil pan, lower pan SOLD
Lower inner and outer timing case and cover.  Also rear main seal cover and thermostat housing.  $100.  Note, the inner timing case needs to be cleaned, still has part of the old water pump that needs to be removed.  Willing to break this set up.
Left and right motor mount arms $75
Left motor mount arm only (dirty) $40
Timing components –Cam sprockets, timing chain guide, timing chain tensioner – All in excellent condition out of a motor that was just rebuilt.  $125
Pics are here
« Last Edit: May 01, 2012, 05:15:43 PM by rob_e30 »
E30PQ
« Reply #1 on: February 12, 2012, 10:56:41 AM »
We wanted to give this forum the first look and the first shot at any of these parts before we start communicating this sale to all of the BMW forums.
Thanks for looking.
rob_e30
« Reply #2 on: February 14, 2012, 07:37:18 AM »
Cylinder head and flywheel pending sale.
E30PQ
« Reply #3 on: February 17, 2012, 07:08:31 AM »
Keep checking this tread as more parts are coming.
zacrl1230
« Reply #4 on: April 30, 2012, 07:04:10 PM »
Bringing back the dead
All this still around??
head shipped to 48701??
WTB:318 \'vert
WTB:SIR tools
WTB:junk
rob_e30
« Reply #5 on: May 01, 2012, 05:16:15 PM »
The only remaining head is good only for some spare parts (#3 dome destroyed).
JayBrown
« Reply #6 on: September 20, 2012, 03:30:57 AM »
Quote
Everything below comes out of my auto parts warehouse or our race trailer. These are spares or parts for future projects that we won’t be using. Many are new or like new, most are cleaned, some need to be taken apart for components and cleaned. All sales are As-Is, local pickup preferred but we might ship at buyers expense. Some of the larger, heavier parts will be expensive to ship. Nothing comes with a warranty, guarantee, or promise of completeness or suitability for any specific application. Please contact before purchasing if you have any questions.
I've tried selling my bmw's parts on a nearby auto warehouse. Wasn't able the whole car so I decided to sell parts of it and it did bring me a good amount of money. Much more than selling it whole. I had greater sale on the abs system and cylinders and engine sensors. Good luck withe the sale though. I'd be waiting for the upcoming parts to add to my wheels.
« Last Edit: February 01, 2013, 10:56:05 PM by JayBrown »
HonaDavis
« Reply #7 on: September 20, 2012, 03:38:13 AM »
I've been also waiting for the upcoming new items/ car parts
