Author Topic: E36 M42 Turbo#Dynoed 500hp and 625Nm#  (Read 30415 times)
KSR AS
    • http://www.ksr.no
« on: February 11, 2012, 05:59:27 AM »
Hello guys/girls
i have a m42 who are lazy and needsome turbo breathing help:-)
here is the setup:
Head:
Ferrea race valves
KSR Race spring and retainers
KSR Cams 270 and 10.6mm lift
Arp head bolts
Block:
Wiseco piston 84.5mm
KSR 140mm H-beam with ARP bolt
Pyramide rings
12.9 bolts for main bearing
Mahle rod bearings
Mahle main bearings
New oil pump
Other setup:
Tial 44mm water cooled Wastegate
Turbo Precision 5454 MFS comp wheel
KDFI Management
650cc Siemens Deka injectors
S50 Throttle bodies
KSR Custom turbo manifold
KSR Custom Plenum
KEP clutch disc
618 pressure plate
M3 ZF transmission
« Last Edit: March 09, 2013, 05:00:32 PM by KSR AS »
KSR AS
    • http://www.ksr.no
E36 M42 Turbo goal around 450HP
« Reply #1 on: February 11, 2012, 06:01:10 AM »
KSR AS
    • http://www.ksr.no
« Reply #2 on: February 11, 2012, 06:04:55 AM »
« Reply #3 on: February 11, 2012, 07:42:46 AM »
Wow.  That's pretty.  It looks fast already, just with the parts sitting there.
Love your workshop too.
KSR AS
    • http://www.ksr.no
« Reply #4 on: February 11, 2012, 08:04:33 AM »
Quote from: DesktopDave;110169
Thanx:-) yes i hopes it will be a great engine..it lives a little devil in me..so it wouldnt surprice me if i put a Precision 5857 with A/r 68 and push the limit :-)
nuvolarossa
« Reply #5 on: February 11, 2012, 08:04:45 AM »
welcome!
cool project!
saw your forum, great builds over there!
« Last Edit: February 11, 2012, 08:18:46 AM by nuvolarossa »
KSR AS
    • http://www.ksr.no
« Reply #6 on: February 11, 2012, 08:20:16 AM »
Quote from: nuvolarossa;110171
welcome!
are you mig welding aluminium? it doesn't seem tig from pics!
cool project!
Thanx:-)
I have Tiged the plenum..but when i Tig this plenum it was much problem with the Tig machine so im not satisfied with the welding.so i will fix it some.the tig machine is for repair now :-)
nuvolarossa
« Reply #7 on: February 11, 2012, 08:35:38 AM »
ah ok, I understand!
I see this is for e36, the turbo will be top or bottom mount?
KSR AS
    • http://www.ksr.no
« Reply #8 on: February 11, 2012, 08:39:34 AM »
Quote from: nuvolarossa;110173
I already have a E30 with 779Whp;-)
Yes for the E36 and the turbo will be infront of the engine..it is so good space between engine and radiator :-)
d.hitchcock
« Reply #9 on: February 11, 2012, 09:39:15 AM »
Wow, that's SO COOL!.
You are an excellent craftsman.
In for the updates.
Cheers,
d.hitchcock
SHAZAM, GOMER, LOOK AHEAD!
KSR AS
    • http://www.ksr.no
« Reply #10 on: February 11, 2012, 11:18:51 AM »
Quote from: d.hitchcock;110175
In for the updates.
Cheers,
d.hitchcock
Thanx:-) i will update often.
bwawuz02
« Reply #11 on: February 12, 2012, 01:44:42 PM »
Why are all the badass builds in Norway???
It's threads like this that drove this year's resolution... LEARN HOW TO WELD!!!
What are you going to run for engine management? stock ECU? aftermarket?
KSR AS
    • http://www.ksr.no
« Reply #12 on: February 12, 2012, 02:29:41 PM »
Quote from: bwawuz02;110213
we loves to get Horsepower out of our engines:-)
i know that my welding on this plenum was not nice..my Tig was joking with me the whole time..i will make better finish on it when my welding machine is repaired.
The management will be The PNP KDFI(based on MS1.3) http://ksr.as/product_info.php?cPath=491_399_400&products_id=1091
« Last Edit: February 12, 2012, 02:40:32 PM by KSR AS »
KSR AS
    • http://www.ksr.no
« Reply #13 on: February 13, 2012, 02:24:40 PM »
bmwconnect
« Reply #14 on: February 13, 2012, 02:51:33 PM »
very nice project
Midnight YouTube Channel
