Author Topic: car not starting  (Read 4009 times)
owenj
car not starting
« on: February 07, 2012, 06:44:55 AM »
Can sum1 please help my car started in the morning for 1min then switched of now it only swings an doesn't want to start wat could be the coz
car not starting
« Reply #1 on: February 07, 2012, 07:03:28 AM »
Do you hear the fuel pump when the car is cranking?  If not, might be the crank position sensor.
Have a multimeter?  Test the crank position sensor's ohms...should be around 640 ohms give or take, solid as a rock.
Gabs
car not starting
« Reply #2 on: February 14, 2012, 03:53:34 PM »
Your details are slightly vague.
I assume by "it only swings" you saying its cranking over but not starting.
Best bet is trial by elimination. Start with the basics, Spark and fuel. I agree with Dave though, inspect the CPS as it could be throwing both spark and fuel off.
A nice way to rule if your fuel pump gave up on you is get some gas in a squirt bottle and spray it in the throttle body, if your car runs for a second you have fuel issues.
