Author Topic: Clutch preload  (Read 2284 times)
romkasponka
Clutch preload
« on: November 11, 2006, 09:54:56 AM »
How to do it right?
E30 318is M42
E36 318is M44
Clutch preload
« Reply #1 on: November 12, 2006, 12:43:54 AM »
Which preload are you speaking of?  As far as I am aware, nothing should be preloaded, unless you are speaking about the clamping force induced on the clutch disc by the pressure plate as you tighten the 6 allen screws on the PP.  Those should be tightened ALL the way down to 19ft-lbs IIRC.  They are sort of a pain too as you have to go around tightening all 6 a couple turns at a time so the PP seats properly.
romkasponka
Clutch preload
« Reply #2 on: November 12, 2006, 06:46:31 PM »
You should mashine flywheel where pressure plate is attached about 0,5mm and you get preload. But it's different on variuos cars.
E30 318is M42
E36 318is M44
