Author Topic: WTB: Interior, Exterior & Mechanical Items - Hawaii  (Read 7394 times)
DRTE30
« on: January 27, 2012, 04:44:23 AM »
Here is an (extensive) list of items that I'm looking for, and this list will be modified as needed. I'm in college and can't really afford to replace everything with retail priced OEM! Actually, I don't know anyone who likes the steelership. I'm looking for OEM or better-than, new is preferred, but not afraid of lightly used/good working order parts either! It's a big list, but my 318is needs some TLC. If anyone has anything laying around and who want's to help a brutha out, that would be stellar! Be ready to negotiate :D ! And send pics if needed! I've done business with FCP and Pelican several times and love their service, so if I get desperate, I'll buckle down and go that route if needed on items that tentatively need to be installed :p .Please feel free to send private messages. Aloha Nui Loa.
Exterior:
* 2-door left door seal. Left: 51711876151M9.
* Door weather strip outer. Left: 51211913055. Right: 51211913056
* Door weather strip inner. Left: 51211953023. Right: 51211953024
* Hood sound insulation set. 51481972245
* Rear right bumper rubber strip. 51121971618
* Front aggregate protective plate (oil pan bump plate) . 51711971001
* Right fog light w/ mount. Right: 63171385946
* Fog light replacement lenses. Sry no part #
* Windshield squirter x2. 61661373401
* Mudflaps front & rear w/hardware. Front: 72601906952. Rear: 72609401168
* License plate/tail light filler plastic covers: 51131961242
Interior:
* Rear view mirror w/ map lights. 51161906525
* Sun roof crank handle. 54121859594
* Illuminated window switch. 61311381205
* Trunk battery cover mounting inserts. No part #. Sry.
Mechanical:
* Front subframe reinforcement kit. TDR3075001
* Lower front chain case cover set. 11141721802
* Lower chain case cover to engine gasket. 11141734422
* Camshaft seal front. 11141439570
* Upper oil pan gasket. 11131739592
* Streetable semi-aggressive front and rear disc brake pads
* Z3 non-M version steering rack. 32131095575
* COP Kit
* Mark D 91-octane chip
* O2 Sensor (need a broken one WITH the wiring clip). 11781727451
* Differential bushing. Sry no part #
* Z4 3.0L shifter lever. 25117543193
« Last Edit: February 25, 2012, 05:32:55 PM by DRTE30 »
« Reply #1 on: February 04, 2012, 03:07:23 PM »
Hey buddy,
I've got these brand new:
P/N 11141721919 - Upper timing case gasket set - might be missing t-stat gasket will check... $5 shipped
P/N 11141247837 - Profile Gasket $5 shipped
DRTE30
« Reply #2 on: February 05, 2012, 01:03:11 AM »
Quote from: dude8383;109992
Hey buddy,
I'll purchase both of those. Thank you.
« Reply #3 on: February 05, 2012, 06:49:52 PM »
PM him for a quicker response...the post was blocked, he might have missed it.
« Reply #4 on: February 06, 2012, 11:42:06 AM »
Quote from: DesktopDave;110021
Hehe, yeh, he pm'ed me earlier asking for assistance to get the thread verified. I wasn't able to get to it sooner. I have since changed my options to get PM notifications via email.
DRTE30
« Reply #5 on: February 12, 2012, 11:09:54 PM »
Thank you for the gaskets (and the interesting BMW magazine) dude8383!
Up.
Matt-B
  • Administratorz
« Reply #6 on: February 13, 2012, 01:32:07 AM »
have these ( maybe the crank ) for sure the front link, there metal ( solid ) and adjustable 20$ shipped
Interior:
Mechanical:
* Motor mounts x2. 11811129286
* Lower control arm M3 bushing set. 31129064875
* Sway bar end link x2 (need something stronger than OEM). 31351091764
* Front upper strut mount x2. 31331139484
* Rear upper strut mount x2. 33521132104
* Rear trailing arm bushing set. 33329061945
* Lower front spring pad x2. 31331124322
* Upper front spring pad x2. 31331128523
* Lower rear spring pad x2. 33531136386
* Upper rear spring pad x2. 33531128610
* Rear swaybar end link x2. 33551126932
* COP Kit
-mA+t B
DRTE30
« Reply #7 on: February 16, 2012, 02:54:34 AM »
Thanks Matt-B!
Up.
DRTE30
« Reply #8 on: June 11, 2012, 01:30:30 PM »
Bumping my thread. I'm currently in Southern Germany/Northern Switzerland for the summer. If there are any BMW Brudern und Schwestern with parts for sale, I would be interested in seeing what you have.
zacrl1230
« Reply #9 on: June 11, 2012, 06:01:19 PM »
YOu should just go to Junkyards and get as many euro only parts as you can bring back
Bumper trims, clocks, and manual window cranks are small and light and valuable :)
I'm just sayin!
WTB:318 \'vert
WTB:SIR tools
WTB:junk
« Reply #10 on: June 16, 2012, 08:23:02 PM »
I was digging around and found a few things you wanted.  I'll post some pictures for you later.
(The lens is cracked & heavily pitted, but the frame & mount are good)
(lights untested)
(the O2 sensor might be good, but it's definitely old.  The BMW wiring connector is definitely functional)
IMHO I'd also get an M20 diff bushing for a 325i or 325is.  They're cheap and far more robust.  I upgraded to a 3.73 medium case and noted that the OEM M42 diff bushing was oh-so-shot.  Unfortunately I can't give you an apples-to-apples "before and after" comparison.  I bought the car with a damaged pinion bearing...driving the car it sounded like a family of raccoons was attempting to escape from the trunk.  It's not very loud now.
DRTE30
« Reply #11 on: June 17, 2012, 03:58:18 AM »
zacrl: Thanks for the heads up on parts.
Dave: I'll pass on your fog light- the replacement lenses are quite expensive and from what I've seen, negate the need to repair as it's better to buy a fully functioning used fog light for slightly cheaper. Though...you're a crafty guy, so I'm open to any repair suggestions!
Would you mind checking the mirror lights and getting back to me with a price? How much for the window switch and O2 sensor as well?
Thanks for the suggestion on the M20 bushing too.
Small side note: I recently bought a mint M-Technik 1 steering wheel and euro front grills for 60 Euro! :)
« Last Edit: June 18, 2012, 12:47:37 AM by DRTE30 »
bimmer7602
« Reply #12 on: September 10, 2012, 04:14:00 AM »
I have front mudflaps and hardware if you still want/need them.  the rears have been missing since i bought the car.  I'll also see if i have anything else you need.  shoot me an offer via text since I'm not on this site too often, I'm also in hawaii so that'll make things a little easier.  (808) 78O-I32I
Sean
blackhawkimpact
« Reply #13 on: September 12, 2012, 11:33:46 PM »
Got these
2002 BMW 325i
1991 BMW 318is S50
1983 Porsche 944
blackhawkimpact
« Reply #14 on: September 12, 2012, 11:35:14 PM »
Got these
2002 BMW 325i
1991 BMW 318is S50
1983 Porsche 944
