Author Topic: Timing System Project: Cam Timing ???  (Read 5190 times)
d.hitchcock
« on: January 26, 2012, 03:52:59 PM »
My buddy Bob and I dove into the M42 today to replace the timing chain, sprockets, and guides, as well as the water pump, thermostat etc.
This is my first foray into the M42 engine, but I've been up to my elbows in M20 several times, so I was looking forward to this.
I'll give a quick blow-by-blow of how we worked. I didn't take photos, and the technical directions are available in Bentley, so I'll just throw out a few extra thoughts.
Also, I have a question about cam timing for reassembly, based on what we found when we pulled everything apart.
We removed the hood for ease of access, then dumped the coolant, pulled the radiator, shroud and fan/clutch assembly. A thin 32-mm wrench from a bike shop and a pulley holder make it easy peezee to remove the fan.
The valve cover, cam sensor, and thermostat and housing came off next, followed by the valve cover and front timing cover and the bottom cover. We had to puzzle over the AC compressor for a moment before decoding the method to unbolt it from the bracket, then remove that honking HUGE AC bracket.
Water pump required just a little persuasion to come out.
We were able to break the crank hub bolt with a honkin' big-azz air gun, the compressor regulator opened up, and the gun primed with fresh oil.
The timing chain, guides and sprockets all appeared to be in good shape, except we discovered the bottom guide had broken into two pieces. The chain appeared to be the same length as the new chain, so no obvious stretching occurred.
One thing that puzzled us was the cam timing. With the crank locked at TDC, we discovered the cams weren't perfectly timed. The intake cam was just far enough off that we couldn't insert the cam locking tool. The cam was off by less than a degree, but just enough to prevent the cam tool from working.
We wound up loosening the bolts on the intake cam sprocket and to allow us to tweak the cam position to accomodate the TDC tool.
I assume the TDC lock guarantees proper cam timing for reassembly, correct? Or do we need to worry about readjusting the intake cam back like it was when we opened her up?
Anyway, we had a blast. I'm anxious to get the car back together tomorrow morning.
We spent about four hours in the shop today, stopping after we installed the new water pump. I had to quit so I could pick my kids up from school and go to work.
We will wrap up tomorrow morning.
Thanks for reading.
d.hitchcock
SHAZAM, GOMER, LOOK AHEAD!
d.hitchcock
« Reply #1 on: January 26, 2012, 03:59:51 PM »
Um, how the heck did I post this thread twice??? :-)
Maybe a mod can delete one of them???
My apologies.
d.hitchcock
d.hitchcock
« Reply #2 on: January 26, 2012, 08:37:08 PM »
Bump!
Hey gang, does anyone have any insight into the cam timing issue we discovered with my car?
Should I set everything with the TDC tools and call it a day?
Thanks again,
d.hitchcock
monko141
« Reply #3 on: January 27, 2012, 12:10:38 PM »
Yes that is the way it is designed.  To keep it perfect leave the cam lock and the flywheel lock in place and leave the cam bolts a little loose.  Install the tensioner and then tighten the cam bolts.
d.hitchcock
« Reply #4 on: January 27, 2012, 04:47:00 PM »
Hey thanks!
We got the car back together today, and it's AMAZING how much more quietly and smoothly it idles and runs now.
All in all, it was a pretty damn fun project. We had no crossthreaded or stripped-head fasteners or other surprises.
Yay!
d.hitchcock
