Author Topic: speedometer problem  (Read 1969 times)
josephb983
speedometer problem
« on: January 19, 2012, 12:30:50 AM »
I have replaced SI batteries, and reflowed all the solder joints on the SI board, and back of speedometer. No avail, the speedometer will not work on acceleration, only after I release the gas.
« Last Edit: January 19, 2012, 11:50:18 AM by josephb983 »
rjcaptsean
speedometer problem
« Reply #1 on: January 20, 2012, 09:21:58 AM »
Sounds like when the torque changes, there might be a loose wire/connection that is pulling loose.  Have you checked the wires going back to the Diff housing and the sensor clip back there?
