Author Topic: Crankshaft and camshaft wiring for standalone HELP  (Read 3042 times)
bossco477
« on: January 13, 2012, 11:37:26 AM »
Hello everyone,
I am installing a Haltech platinum sport 1000 on my 318 is. So far everything has gone well except for the crank and cam sensors.
I am confused about how to wire them. Initially, while the stock ecu was plugged in I measured with a multimeter the output from the main wiring harness to the sensors. I found that for the crank pin 1 is a positive 5v, pin 3 is a ground and pin 2 (I assumed) is a signal. In other words I set it up like a hall effect sensor.
Doing some research I found that the camshaft sensor is a VR (variable-reluctance) sensor.
Now, on the camshaft I did the same thing and found a constant voltage through the two outer pins but in this case it was extremely low in the order of milivolts
From what I underestand a reluctance sensor only needs a positive and a negative.
My questions are:
1. Which two pins should I use for the crank and the cam assuming they are both reluctors?
2. Do the ignition coils have igniters built in?
Thank you in advance and I would appreciate if you have any advice or any other notes I should be aware of
Boyracer
    • http://www.jannousianen.net
« Reply #1 on: January 17, 2012, 04:54:56 AM »
What year is your 318is? I think there has been 3 different M42 revisions and also M44 engines installed during years. M42 have two VR sensors I think and M44 had one or two Hall effect sensors so it matters.
1993-1995 M42 sensors have yellow and black wires for signal.
1996-1997 camshaft sensor has yellow and yellow or red/white wires for signal.
M42/M44 coils do not have internal igniters.
romkasponka
« Reply #2 on: January 26, 2012, 06:29:56 PM »
You can use igniteers from new like E90 models with little enlarged diameter in cylinder head cover.
E30 318is M42
E36 318is M44
