Author Topic: Standalone HELP neede, cam and crank sensors Haltech  (Read 2232 times)
bossco477
« on: January 13, 2012, 01:12:49 AM »
Hello everyone,
I am installing a Haltech platinum sport 1000 on my 318 is. So far everything has gone well except for the crank and cam sensors.
I am confused about how to wire them. Initially, while the stock ecu was plugged in I measured with a multimeter the output from the main wiring harness to the sensors. I found that for the crank pin 1 is a positive 5v, pin 3 is a ground and pin 2 (I assumed) is a signal. In other words I set it up like a hall effect sensor.
Doing some research I found that the camshaft sensor is a VR (variable-reluctance) sensor.
Now, on the camshaft I did the same thing and found a constant voltage through the two outer pins but in this case it was extremely low in the order of millivolts
From what I understand a reluctance sensor only needs a positive and a negative so I need to rewire my cables going to my Haltech.
I would appreciate if someone could answer some of my questions:
1. Which two pins should I use for the crank and the cam assuming they are both reluctors?
2. Do the ignition coils have igniters built in
Thank you in advance and I would appreciate if you have any advice or any other notes I should be aware of
Mario Hdz
