M52 - Around 90k
Block was cleaned and painted Black
Head:
pressure tested
cleaned
decked
complete valve job
new valve guide seals
s52 camshafts
Wrinkle black powder coated valve cover (needs to be installed)
Copper O-Ringed Block
.140” MLS head gasket
ARP 2000 head studs torqued using new lube/spec
New thermostat with aluminum housing
Stewart Water Pump
OBD1 crank sensor
asking $1600 obo
i have a Ton of other stuff for it that will be available to whoever buys this
Good & Tight Turbo Manifold
New Coils
M50 Intake
e34 Oil Pan Set Up
and more Turbo Items Related
will shipp if needed
