Hi i'm building up my e36 m42 with turbo kit with Original Ecu without programing it and i'm searching for solution to increase fuel sprayed to engine becouse when turbo blows up to 0.5 bar fuel isnt enough and when you push the pedal maximum it doesnt work properly , tryed to fit in 740 injectors nothing changes, maybe its possible somehow to trick original ecu to spray more fuel or try to add Additional fuel injector to intake manifold? Is it possible somehow to canculate fuel mixture? and how much more fuel i need when pressure increases? I would be thankfull if someone could help me to find a solution to my problem. thanks (sorry for my english)
