Author Topic: Assorted parts! Steering wheel/hub, interior stuff, and M42 parts.  (Read 3115 times)
Analog
I'm really just trying to get rid of a lot of this stuff, so no reasonable offer will be  denied! I'm not trying to make a fortune on this stuff, just trying to get it out of my garage.
ALL PRICES ARE SHIPPED
First is an unknown brand wheel hub, and a Raid "Dino" wheel. Light wear and cracking, but 100% usable. I think the the wheel is a 330mm diameter. I can measure tomorrow. It's pretty small. The wheel hub is an unknown brand. It was removed from my 9/89 M5(Same hub as e30) and it's been on the car since it was imported from Germany. So who knows what brand it is!
NO SEPARATING THESE!!!!
$80 shipped for the pair.
Parchment door coin tray. These were originally options for E34's, but I have found that they fit perfectly in the door cards of E30's as well! Great condition!
$16 shipped.
Leather E-brake handle. $9 shipped
M42 water pump. Used for about 500 miles or so. Has a little surface corrosion in places, but it is a water pump, so what do you expect? ;) Purchased new for $61, will sell today for $30 shipped!
M42 power steering pump. It's grimey but it works perfectly! $20 shipped!
M42 alternator. Good working condition! Ready to be installed. $35 shipped.
M42 AC compressor. I spend about 20 minutes cleaning this up, but unfortunately, I won't be able to use it :( It is in good working condition.
$37 shipped
M42 ECU removed from my 1/91 production date 318is. Works great and ready to go!
$27 shipped
M42 pulleys. $14 shipped for any pulley/harmonic balancer off the engine. I also have the outer crank pulley.
M42 wiring harness. It's in great usable shape and is ready to go on your engine! No cut wires! $43 shipped
M42 thermostat housing, less than 500 mile thermostat, NEW thermostat O-ring, and NEW thermostat gasket. I'd rather not split this stuff up.
Take it all for $20 shipped
M42 igntion wires. I have 7 assorted wires total. How does $4 each + $4 shipping on them sound? Name which ones you want, and I will send them your way!
Assorted replacement hoses for M42 engine. Replace those cracked worn hoses with these 4 NEW ones! I ordered them a while ago, and I honestly forgot what each individual one was for. M42 aficionados could probably pick them out though. NO SEPARATING! $20 shipped for the set!
M42 IACV. It works. Not much else to say. SOLD
M42 coil packs. All 4 work perfect. $25 shipped for the set!
« Last Edit: December 18, 2011, 06:38:20 PM by Analog »
longms
« Reply #1 on: December 29, 2011, 11:06:00 PM »
great prices!!!
