Reseting the AFM to factory setting
Author Topic: Reseting the AFM to factory setting  (Read 3299 times)
spanish_pants
« on: December 12, 2011, 03:54:52 AM »
Well gentlemen that is the question. Mine has been tampered with by the previous owner, and then by a less than knowledgable shop after i added some mustang injectors.
I need to get it back to stock so i can get the new chip working properly with the new injectors.
Thanks!
« Reply #1 on: December 12, 2011, 07:19:16 AM »
Sounds like a good idea...but there's a possibility that they were all separately calibrated.
I'll see if I can dig up more info.  It's a voltage curve that they put out, I'll bet Bosch calibrated them on a flow bench.
bmwconnect
« Reply #2 on: December 12, 2011, 09:43:46 AM »
desktop is correct, they were all separately calibrated at the factory.
Midnight YouTube Channel
spanish_pants
« Reply #3 on: December 14, 2011, 06:40:31 AM »
Really? would it be best to just get a new one or have it adjusted to work with the new chip and injectors?
bmwconnect
« Reply #4 on: December 14, 2011, 01:09:22 PM »
The best way to get it back to stock, would be to run the stock chip, remove stock lambda sensor, and have someone hook up a LM2 or equivalent sensor to measure the exhaust gas. Adjust spring till you see 13.5 AFR, then you can stick your performance chip and injectors in.
All the best!
« Reply #5 on: December 14, 2011, 03:41:20 PM »
My advice is to find one at a junk yard that doesn't appear to be tampered with, and use that. If you are feeling like spending money, you can get a Python Injection rebuilt one, and send in yours for a core refund. It may run you around $200.
Otherwise, you will need a wide-band O2 sensor and some trial & error to get this one close to its original calibration. Sorry it isn't a cheap, easy answer!
spanish_pants
« Reply #6 on: December 16, 2011, 03:49:58 AM »
Quote from: bmwconnect;108894
All the best!
Right now i´m not running the chip. In order to get it to work properly i need to install an o2 sensor, but i am running the mustang injectors. With out an o2 sensor these were running rich, hence the previous afm adjustment.
I think i´ll go back to stock and take youre advice as a first option as it seems the most cost effective route. If this fails then i´ll just go with a new or rebuilt afm.
spanish_pants
« Reply #7 on: December 16, 2011, 03:53:43 AM »
Quote from: bmwman91;108900
It´s tough to find these at a JY, as there are very few is´s and what there is has been sitting there under the elements for years.  Let´s see if my first option pans out.
« Reply #8 on: December 16, 2011, 07:23:54 AM »
I'll bet there are a few equivalents...my E34 525i had a very similar AFM, I wouldn't be surprised if it was exactly the same.  The updated later round connector is the only change that's significant.
http://bmwfans.info/parts/catalog/13627558785/
All the M42 & M44 units are interchangeable according to the BMWFans x-ref above.
