Check the connections on the oil & coolant sensors. I swapped mine and had a dim oil light on all the time. Those connectors are all the same, I never seem to get them right the first time.
Let the motor "break in" a little bit, especially if it's been sitting. The tensioner & lifters will need some time to get unstuck, especially if it was running on dino oil.
I usually run a bit of ATF with a cheap thin synthetic oil (0w20 - or even better - used synthetic) in a motor that's been sitting for a while. Don't go crazy with it though...at most run only 1/4 ATF and only with light loads & gentle driving. No rush hour either!
If you want to clean it faster, SeaFoam is magical for old motors. It's better on carbs, I'd skip the fuel treatment bit. Just follow the directions on the can. BTW, it'll smoke like the devil and reek like nothing else if you add it to the gas. Once it's been 'Foamed, change the oil to a more normal 10w40 or 15w50 and drive it normally (like you stole it, in my case).
