Author Topic: E30 parts socal  (Read 6223 times)
Ex-m20_owner
E30 parts socal
« on: December 06, 2011, 05:49:32 AM »
-E30 Control arms with good stiff ball joints and myle cab $100
-E30 Arms straight and clean ready for new ball joints $60
-1991 318is Cats quick story about the two cats is I rebuilt my m42 but had the temp sensor
plugs switched around so got a check engine light and car failed smog so I had another cat
welded on and switched my abs light for the cel, I was in a rush and just needed regestration
cats are good so is piping do what you want with it $100
-E30 Coupe door cards in red with black handles and pockets front and back $110
-E30 beige door cards two sets one with cloth centers $60 a set
-E30 Sport seats all functions work drivers seat is tore up $100 for pair
-E30 battery covers $15 each
Ex-m20_owner
e30 parts (2)
« Reply #1 on: December 06, 2011, 05:54:07 AM »
-1991 318is headliner no rips tears, material is still soft from non smoker car $90
-E30 Cabrio sway bar w/good links and good bushings upgrade over non coupe and sedan bars $75
-E30 splash guards from various years all in good condition $15 each
-E30 Supersprint cat back from my 90 325is have had it for 4 years since new but only on my car for a year 8/10 condition sounds great. retails for $800+ from turner Ill take half of that $400 picked up
-E30 90 325i auto driveshaft with new csb and guibo u-joint are like smooth $120
-E30 86 325e 5 speed driveshaft, csb is ripping u joints are smooth $80
-E30 91 325is driveshaft rebuilt needs csb to be like new $150
-E30 91 318is rear half of driveshaft $20 someone out there has my other half lol..
-E30 88 325is sport wing rubber is good, studs intact $50
-E30 Center counsole all in good condition $20 each
Ex-m20_owner
e30 parts (3)
« Reply #2 on: December 06, 2011, 05:56:51 AM »
-E36 Front crossmember one good motor mount $40
-E30 1991 318is wiring loom with coils, relays & new temp sensors $120
-E30 1991 m42 cracked head but had 140k when cracked. Lifters, gears, cam lobes, bearings, springs and valves all still look new $100 for the whole thing or i can strip the head dont care.
-E30 A/C compressor not sezied and system still held pressure when taken off the car $45
-E30 alternators all in working condition $40
-E30 starters one is from 91 318 one is from a 85 325e and the rest are from 325i $40 each
-E30 Brake calipers from 90 325i no leaks or rips is dust boots $40 for set
-E30 p.s. pumps all in working order $35 each
Ex-m20_owner
e30 parts (4) socal
« Reply #3 on: December 06, 2011, 05:58:16 AM »
-E30 fan with good oem behr clutch $35
-E30 behr fan clutch by its self like new $25
-E30 5 speed swap clutch and brake pedal for the 5sp conversion $40
-E30 auto brake pedal $5
-E30 trans crossmember and brace $10 each good set of oem mounts no oil on them $5 for pair
-E36 Inner and outter tie rods good ball joints and comes with good non cracked dust boots $30
-E30 Ate & Fag slave cylinders one is pretty much brand new other is still good New one $20 other one $10
-E30 guibo like new for 88+ e30s $10
-E30 updated cooling system water pump only used for a short period of time crashed my car $20 absolutly no play in bearings spins like new
-E30 Ireland Engineering crank scraper never installed sells new for $48 Ill take $35
-anything else you see i have just let me know i dont need anything you see in the pics
E30 parts socal
« Reply #4 on: December 06, 2011, 10:01:04 PM »
Posts merged.
Ex-m20_owner
E30 parts socal
« Reply #5 on: December 07, 2011, 02:17:32 AM »
Thanks for the help !
Quote from: dude8383;108712
Posts merged.
Ex-m20_owner
E30 parts socal
« Reply #6 on: December 08, 2011, 01:13:51 AM »
end of day bump!
rob_e30
E30 parts socal
« Reply #7 on: December 09, 2011, 03:27:08 PM »
PM Sent
Ex-m20_owner
E30 parts socal
« Reply #8 on: December 09, 2011, 10:04:07 PM »
Pm Replied
Quote from: rob_e30;108768
PM Sent
E30 parts socal
« Reply #9 on: December 11, 2011, 04:10:33 AM »
Would you happen to be able to get windshield washer parts? I need a tank, the screw that secures the tank, the pump and the hose-tee that splits the lines. Also, I could use the plastic shrouds that go behind the headlights and the plastic screw/clip things that hold them (+4 extras for other missing ones). And, finally, I could use a new emergency flasher switch with functional back-lighting.
All 1991 (or compatible) E30 parts, of course.
E30 parts socal
« Reply #10 on: December 12, 2011, 05:15:42 PM »
Bump for a great seller!  My parts were shipped out immediately & arrived in even better condition than promised!  Thanks again!
Ex-m20_owner
E30 parts socal
« Reply #11 on: December 13, 2011, 03:33:31 AM »
Quote from: bmwman91;108804
I do have everything you are asking for, I will pm you tomorrow after I round it all up. Ill give you a good deal aswell
Quote from: DesktopDave;108846
Thanks Dave every bit helps my garage get a little cleaner everyday :)
E30 parts socal
« Reply #12 on: December 13, 2011, 07:16:10 AM »
Quote from: Ex-m20_owner;108860
That's what we're here for, clutter removal. :D Though I'm not responsible if this ends up on TLC as the BMW episode of "Hoarders."  I'm dangerously close to that myself...never know when you'll need a spare!
Ex-m20_owner
E30 parts socal
« Reply #13 on: December 15, 2011, 12:02:12 AM »
I found one of the screws that hold the those headlight back covers Im sure I have a few more just got dig through some of my bags of miscellaneous stuff and I had no idea the hose for the wipers is made by VDO lol.. Also I dont have a cap for the wiper rez.. asuming I find the other 3 screws what do you think would be a fare price on all this? Ill pay shipping..
Ex-m20_owner
E30 parts socal
« Reply #14 on: December 15, 2011, 12:25:25 AM »
Everything is clean I have an assortment of switchs and stuff like that I know I have the clips for the head light covers and I dont have the top to the wiper reservoir tho have no idea where it is..
 What do you think would be fair on all this? Ill pay shipping.. I have verified paypal too! I will also verify that the hazard switch works in my e30 b4 anything.
