DISCUSSION
Engine + Driveline
Injector choice
Topic: Injector choice (Read 2413 times)
bbarnumboy
Injector choice
December 04, 2011, 04:21:25 PM »
I am going to be replacing my injectors with a 42lb Mustang type injector. Does my e36 M42 run low or high impedance? need to find the right ones to do a direct swap.
FYI i know the are bigger and i am using a fuel management to use them.
bflan2001
Injector choice
December 04, 2011, 07:40:38 PM »
high impedance, from what i'm reading 42lb is way overkill unless you plan on making over 300hp
Administrator
Legendary
-Receive: 60
Lives in the 80s
Injector choice
December 04, 2011, 08:29:55 PM »
+1. High impedance & looks like PN 0280155968 is a pretty common choice. You'll be sharing them with high pressure turbo Volvo's & Porsche 928's:
http://www.fiveomotorsport.com/import-high-performance-fuel-injectors/?itemid=334
Injectors that are too large will cause you some idle & low speed troubles. Depends on how big that blower will be, I guess.
bbarnumboy
Injector choice
December 05, 2011, 10:02:54 AM »
I will be running 15psi I went with the 42 Lb Mustang injectors. Just wanted to make sure the mustang ones would be the correct Impedance.
Thanks guys
DISCUSSION
Engine + Driveline
Injector choice
