I'm rebuilding my M42 to stock specs except with M50 pistons (for a comp ratio of 8.5:1), and a few things to reduce valvetrain weight (vw lifters, single row chain & sprockets). I also have an MLS headgasket, raceware hardware, and I'm thinking about VAC coated main & rod bearings. That being said, if I slap on either a t28 or t3 turbo and boost it to about 10psi, will that get me anywhere near 200WHP?
Now onto the more complicated questions...
What turbo would you recommend for a mild build on a budget? I'm looking for power that kicks in low, rather than the rubber band feeling you get from big turbos on small motors. This is my DD so driveability & reliability are important.
Originally I wanted to buy an m47 crank, s50 pistons & custom rods but it seems like that is a lot of investment for a relatively small return (at least when you add a turbo to the equation). I read that you can use the M50 pistons with otherwise stock internals, can someone confirm this?
Again, concerned about $$, I'm hoping I can avoid custom engine management & tuning. Is this a reasonable expectation? To me it doesn't make sense that you can use the stock ECU with a turbocharger, but it looks like it's been done before. I bought a RRFPR hoping it will help avoid custom tuning.
That's all for now, looking forward to your expert opinions and advice. Please feel free to make suggestions/recommendations that I didn't ask about. This is my first complete motor rebuild as well as my first turbo build so I can use all the help I can get. Thanks in advance, M42 gurus!
