Author Topic: m42 / m44 interchangeability  (Read 2662 times)
wodcutr
« on: November 26, 2011, 09:02:47 AM »
I just bought a 98 318ti without a motor and was wondering if anyone could tell me if an m42 would be a usable motor in place of the m44 or should I just source a good m44 because it is not worth the hassle to convert.  Thanks!
« Reply #1 on: November 26, 2011, 11:18:47 AM »
Go with an M44.  There are significant differences between the electrical systems.  For instance, none of the M42's have a MAF (all are the flap-type AFM), among other differences.
If you really wanted to get the best of both worlds I'd use parts from  both.  I strongly suspect it can be made to work, but I'd go for the M44 if you're looking  for plug-n-play.
You could use an earlier M42 if you swapped out the entire harness as well, but that raises legal problems...our mechanics in PA would cite the missing OBDII as a safety & emissions inspection fail.  Our DOT isn't even that strict, can't imagine what it'd be like in CA...
rsdvr6
« Reply #2 on: November 27, 2011, 05:00:39 PM »
I ran across a fresh M44 yesterday at my local pull n save, was thinking about a pulley swap for my '91 M42 but the alternator seems like it may pose a challenge. I would do the M44 unless you ditch it all and do a "big" six swap. Let's hear it for an S52 318ti!
wodcutr
« Reply #3 on: November 28, 2011, 09:30:36 AM »
I thought about throwing a 6 cylinder in there, but the car is for my daughter and I doubt she would appreciate a swapped ti!
