Author Topic: AFR Problem at Idle ?  (Read 2149 times)
Threehz
« on: November 23, 2011, 02:16:35 PM »
Ok so after driving a while when I come to a stop and sit at idle for a while my check engine light lights up. The second I give it any gas it goes away.
Turns out it is code 1222 Lambda Control #1 which means the AFR is too lean or rich for longer then 10 seconds. Not great since the list of possible causes is so long but at least it's a start.
Since it is only coming on when I sit at idle for a while this means that it's only getting too rich/lean during idle.
So what would cause me to be too lean/rich only at idle?
Also the car is showing no symptoms as far I can tell.
91 e30m42
« Reply #1 on: November 23, 2011, 03:04:37 PM »
i would check your oxygen sensor as that what happened to mine it went bad before my engine swap...
bmwconnect
« Reply #2 on: November 23, 2011, 03:39:20 PM »
O2 sensors failing will get slow and throw a code - *I would swap this out first* A simple bench test with a propane torch and voltmeter can show you if the sensor is still working correctly and swiftly
If you still have a problem, then I would look at the injectors, fuel pressure , & fuel pump, spark plugs, and finally the exhaust gasket at the headers
good luck sir
Midnight YouTube Channel
« Reply #3 on: November 23, 2011, 04:15:32 PM »
Check the O2 heater relay.  I'm thinking that the O2 sensor is cooling off too much & throwing a code.
Could also be the usual stuff...vac leak, low fuel pressure, faulty FPR...
