DISCUSSION
General Topics
condenser fan,diagram inside
Topic: condenser fan,diagram inside (Read 3775 times)
stillmatick
November 02, 2011, 04:16:22 AM »
Is this the correct way to make condenser fan independent to a/c switch???
If so should I put 30amp fuse holder between condenser fan and a/c switch??
Last Edit: November 02, 2011, 04:35:32 AM by stillmatick
DanOKC
Jr. Member
November 08, 2011, 10:46:25 PM »
NO, I wouldn't do that. What do you want to do ? Have a switch to turn the condensor fan on at anytime, or off at anytime ? or ?
stillmatick
November 10, 2011, 12:42:42 AM »
setup has two electric fans. One is the original aux (condenser) fan aka 16inch spal curve pusher and the other is a new electric radiator fan. Both fans will only run at a single full speed. Replaced the radiator switch with the 80/88C switch. With these changes,fans will run as so:
1. Temp hits 80C. Radiator fan kicks on.
2. Temp hits 88C. Aux fan kicks on to supplement the radiator fan.
3. AC is turned on. Both fans come on.
the new radiator fan plug and play,e36 electric fan.
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=64-50-8-372-039-M262&catalog_description=Cooling%20Fan%20Assembly%2C%20with%20Shroud%2C%20Located%20between%20Radiator%20and%20Engine%2C%20318i%2Fis%2FiC%20%281992-98%29%2C%20318ti%20%281995-99%29%2C%20Each
DanOKC
Jr. Member
November 10, 2011, 10:12:35 PM »
OK, what behavior are you trying to achieve for the fans ? with regards to AC on, AC off, temp switch low 80 or temp switch high 88. please elaborate a bit. and this is an E36 ?
DISCUSSION
General Topics
