Author Topic: strut brace?  (Read 10150 times)
318is1506
strut brace?
« on: October 26, 2011, 07:09:48 PM »
ok i see alot of strut braces out there and i was wondering if they really make a big enough difference to justify the cost ? and if so what are the major differences ?
mr.vang
strut brace?
« Reply #1 on: October 26, 2011, 11:50:53 PM »
only if you track it.
fs: air bag model knee panel, bmw tools, ects
visionracingdevelopments
strut brace?
« Reply #2 on: February 20, 2012, 12:51:27 PM »
I think it's worth doing no matter what you're doing with the car. These are great cars to drive, anything that adds a bit of front end strength can't be a bad thing. If you get one avoid the cheap nasty aluminium ones which are only good for the scrap bin!
http://www.visionracingdevelopments.co.uk
For sale:
COP converion kits
M42 Silicone coolant hose kits
Braided brake line kits
Performance clutches
Performance brakes
PM me
d.hitchcock
strut brace?
« Reply #3 on: February 20, 2012, 01:29:43 PM »
Mason Engineering makes a pricey but very nice strut brace.
I have an Ireland Engineering brace on my autoX car. It's identical to a Sparco brand brace, but black instead of Sparco red.
d.hitchcock
SHAZAM, GOMER, LOOK AHEAD!
bwawuz02
strut brace?
« Reply #4 on: February 22, 2012, 11:15:51 AM »
Quote from: mr.vang;107700
If you own an E30 and haven't upgraded the suspension, you're old and don't know how to live... With modest upgrades (including a strut bar) these cars are a blast to drive and will dart thru traffic with ease.
You say tracking, I say daily commute... potayto, potahto. to each their own :D
make sure you get a solid bar, the sparco copy by IE is probably the best bang for your buck.
« Last Edit: February 22, 2012, 11:17:52 AM by bwawuz02 »
strut brace?
« Reply #5 on: February 22, 2012, 02:43:18 PM »
The M42 manifold in the E30 sits quite high so it can be hard work finding one that clears it.
For sale:
COP converion kits
Performance brakes
PM me
d.hitchcock
strut brace?
« Reply #6 on: February 22, 2012, 04:45:42 PM »
Quote from: visionracingdevelopments;110487
Any idea if the Sparco/IE fits?
Or not???? ;=)
If I had the extra money handy, I'd spring for the Mason bar for my 318is.
bwawuz02
strut brace?
« Reply #7 on: February 22, 2012, 06:29:38 PM »
yeah, I've seen it installed with no problems and seen people who took a mallet to the bottom of the bar to "clearance" the intake manifold... get some ITBs and it shouldn't be a problem :D
Hey-u
strut brace?
« Reply #8 on: February 22, 2012, 08:52:27 PM »
I have the sparco. Very tight fit, I had to use a washer to get enough clearance.
d.hitchcock
strut brace?
« Reply #9 on: February 23, 2012, 01:31:53 AM »
ITBs: Roger that. :D
strut brace?
« Reply #10 on: February 25, 2012, 01:03:40 PM »
I used to have a Sparco one but it didn't fit so I had to move it on. I then had an Ultra-racing one which did fit, but it was VERY close and I know people who had them but they didn't fit. I expect that one fitted because my engine mounts were buggered. Only bad thing about it was the fact the holes were slotted so it could move if under enough force, which is hardly desirable for a strut brace.
For sale:
COP converion kits
Performance brakes
PM me
stillmatick
strut brace?
« Reply #11 on: March 03, 2012, 02:25:42 AM »
ur racing bar fits on m42
http://www.madmotors.co.uk/ultra-racing-bmw-e30-3-series-front-upper-strut-brace-48453.html
PJH318is
strut brace?
« Reply #12 on: November 25, 2012, 09:10:44 AM »
I have a Hartge bar in the front, no bar in the rear.
When I first placed it, I wasn't very happy with it. The car had a tendency to understeer more and I don't like that. It does sharpen the turn-in responce because the car is more rigid, but once that fase is out of the way I found it to be troublesome. So I removed it.
A couple of months later, I placed excentric M3 control-arm bushings -> these add more caster to the car, which also increases the dynamic camber in corners. So the car had more front-end grip.
I then placed the brace back and the end-result is a more balanced car in the corners.
So the best answer to your question is: if you drive fast, even on public roads, but don't really have any other mods, I wouldn't do it. If your car is setup for some fun, I do recommend it.
romkasponka
strut brace?
« Reply #13 on: November 25, 2012, 12:23:44 PM »
strut bar should be as straight as possible and all U shape strut bars are not  rigid enough. Diameter also should be big enough.
E30 318is M42
E36 318is M44
strut brace?
« Reply #14 on: November 25, 2012, 03:35:40 PM »
