Author Topic: Offset question.  (Read 4736 times)
FL318is
Offset question.
« on: November 01, 2006, 02:44:09 PM »
Found a set of 16x7, 38mm offset including 10mm hubcentric spacers, 4x100.
Will this fit on our 318is?
RED E30
Offset question.
« Reply #1 on: November 01, 2006, 02:52:22 PM »
With ET28 the clearance issues will depend on the design of the wheel.  Some wheels would clear some may not.  A trial fit may be the only way to be 100% certain of knowing.
2002maniac
Offset question.
« Reply #2 on: November 01, 2006, 05:28:54 PM »
I'd be willing to bet they would work fine.
if you used 15mm spacers I would guarantee perfect fitment.
FL318is
Thx
« Reply #3 on: November 02, 2006, 07:41:57 AM »
Always a challenge when doing math in the head! :p
Alpine003
Offset question.
« Reply #4 on: November 02, 2006, 11:07:51 AM »
Generally a 6" width can be up to 35mm while 7" can be up to 25mm to clear the strut housings. So 38-10=28mm would be close and I'm sure would depend on the amount of contact patch and size of the tires as well as your camber settings.
FL318is
This is the rim.
« Reply #5 on: November 02, 2006, 12:37:17 PM »
Of course I would be getting the 4x100.
FL318is
OTAY then!
« Reply #6 on: November 02, 2006, 12:39:55 PM »
Quote from: Alpine003;13197
So what 2002maniac said, "I'd be willing to bet they would work fine. if you used 15mm spacers I would guarantee perfect fitment." . would be the way to go!  Go from a 10mm to a 15mm spacer.
Choking Hazard
Offset question.
« Reply #7 on: November 07, 2006, 09:03:03 AM »
Man those are purty.  Got some nice callipers & rotors to put behind 'em?
[SIGPIC][/SIGPIC]-Scott
M42boy
Offset question.
« Reply #8 on: November 09, 2006, 12:33:47 PM »
Quote from: 2002maniac;13134
If you go with spacers, please remember to use longer wheel bolts!  :rolleyes:
Alpine003
Offset question.
« Reply #9 on: November 09, 2006, 12:59:32 PM »
Quote from: M42boy;13556
I've had good experience with Vorshlag. Their prices are pretty good for wheel stud kits too. http://www.vorshlag.com/wheelstuds.php
2002maniac
Offset question.
« Reply #10 on: November 10, 2006, 03:38:32 PM »
Quote from: Alpine003;13557
Yup. I have their studs as well.
Order a few extra studs and nuts and ALWAYS put anti-sieze on them.  I slacked and ended up with two galled studs :(
n2motorsports
Offset question.
« Reply #11 on: June 13, 2007, 01:17:14 PM »
rims are 15x6.5 offset 34mm
Will they clear strut side with aftermarket strut/spring.
thanks.
Vladi
    • http://www.bmwzone.ro/forum
Offset question.
« Reply #12 on: June 13, 2007, 04:27:21 PM »
Yes.
