how can one tell without taking it off and backflushing(?) it?
i recently put in
- a new head (shaved and valve job) because the previous head cracked.
- new headgasket
- fairly new thermostat
- and i bypassed the heater core as well.
i bypassed the heater core because i wasn't so sure what the hell was going on.
originally the pipe coming from the side of the block was plugged in the lower heater core pipe and the other coolant hose that's coming from the end of the block was plugged on the upper coolant pipe on the firewall.
the lower one was cold. i tried swapping them. which did the same thing with the same hoses, one of them were cold. so i just assumed that the heater core(and or valve) was shit. so i bypassed it and connected the two hoses together.
i noticed that the two rad hoses upper and lower were both hot.
so that means the thermostat opened right?
i proceed to rebelled the cooling system.
i noticed that the bleeder screw at the bottom, though screwed tightly shut, was still dripping. wtf?
till now my temp keeps going 3/4 like how the car was before the original head cracked.
at this point i'm not too sure if it's the radiator or the temp gauge fucking with me. i really really don't want to risk running 3/4 temps given that my head is new.
any ideas?
