Author Topic: Timing chain replacement  (Read 2111 times)
bflan2001
« on: September 24, 2011, 10:13:30 PM »
How common is it for the crank sprocket and cam sprockets to wear out? I have everything needed to replace the chain, all guides, tensioner and oil pump rotor. but those last three sprockets are expensive. I won't be able to check them out for another two weeks, and if they are a common replacement during rebuilds I might just order them.
« Reply #1 on: September 25, 2011, 08:54:16 AM »
Crank wear is rare from what I've seen.  Cam gear wear is common.  You may want to replace the idler gear or bearing as well.  Those have a tendency to fail at high mileage as well.
bflan2001
« Reply #2 on: September 25, 2011, 11:50:28 AM »
thanks dave..i can't find a part number for the idler gear or bearing, could you link me to those parts?
i'm using the link below to put together a kit, i have everything there along with a few other items, but he doesn't mention the idler gear.
http://www.esatclear.ie/~bpurcell/318istimingchain.html
