Author Topic: TDC trigger wheel tooth?  (Read 3381 times)
wazzu70
  • Nasty Nick
  • -Receive: 18
« on: September 23, 2011, 11:40:23 PM »
I lined my crank up to TDC and counted 20 teeth back to the VR sensor. Is this what other people have found for their config files?
This is with the first tooth after the gap being 1 and not 0 so 20 physical teeth.
Just wanted a confirmation from someone else :)
Thanks.
-Nick
91 E30 M42 with VEMS
MLM
  • -Receive: 10
    • My M42 ITB Project
« Reply #1 on: September 24, 2011, 02:41:03 AM »
Quote from: NickHertlein;106893
Thanks.
I have a Link G4 which works with  degrees. it required -115 degree from memory to get the correct tdc reference of the first tooth. seems like your on the right track for your ecu
« Last Edit: September 24, 2011, 06:31:30 AM by MLM »
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #2 on: September 24, 2011, 10:39:24 AM »
Each tooth is 6 deg of rotation (360 deg/60 teeth). Yours is 19 teeth. Not sure how your ECU works though. Mine has a first trigger tooth and then degrees after FTT as the variable. If you have FTT as tooth 1 then we have the same thing.
I will verify my counting again today :)
Thanks for the reply!
-Nick
