Author Topic: any members in eastern PA  (Read 10867 times)
91E30
« on: September 21, 2011, 07:33:07 PM »
Hey, im new on here,  just bought a 318is with a blown motor, any other members around philadelphia?
Mark
« Reply #1 on: September 22, 2011, 07:09:55 AM »
I'm over in Pittsburgh myself.  I think JorgeConrico is in West Chester, but he hasn't been active in a while.
« Reply #2 on: September 22, 2011, 07:20:51 AM »
Check these links out for a motor:
http://philadelphia.craigslist.org/pts/2568463606.html
http://philadelphia.craigslist.org/pts/2581378213.html
http://philadelphia.craigslist.org/pts/2583362714.html
You might get lucky, nobody really wants M42's.  I'd get on R3v & see if anyone is doing an M52 swap & looking to sell off the old motor reasonably.  You just missed an entire power train/harness & DME in Jersey a couple months ago for $350.
colin86325
« Reply #3 on: September 22, 2011, 12:31:49 PM »
Hi there, I am in Chadds Ford, near West Chster.  Welcome aboard!
91E30
« Reply #4 on: September 22, 2011, 01:58:08 PM »
Quote from: DesktopDave;106836
thanks! yeah i know i saw that motor, by the time i talked to him it was already gone. do you know what year m42s will fit in these cars? my cars an e30 and ive been told the newer motors wont fit.
91E30
« Reply #5 on: September 22, 2011, 02:01:44 PM »
Quote from: colin86325;106838
Thanks, im not to far away in Delaware county
91E30
« Reply #6 on: September 22, 2011, 02:03:27 PM »
thanks for the links!?  does anyone know what year motors will swap in? ive been told the ones from e36s wont fit.
« Reply #7 on: September 22, 2011, 08:16:16 PM »
I haven't done it, but I'm pretty sure all the e36 motors will swap, even M44's.  Unless you want to get creative, knock sensors won't work, and you'll have to swap the DISA intake manifold for your stock e30 one.  Oil pans are different too, swap the old one over.  Later models had serpentine belt drive, you might be able to use them as-is or replace the pulleys for the stock e30 v-belt setup.
Later ones had the improved timing chain deflector rail and tensioner as well.  The M42 was installed up to '96 IIRC.
91E30
« Reply #8 on: September 22, 2011, 09:05:25 PM »
ook thanks! cause i have easy access to  a later e36 M42. sittin in a bmw yard by my house. if i can find more info on the swap i will definitly do that.
if not, ill keep looking for an e30 motor, for less then 1300 bucks
« Reply #9 on: September 23, 2011, 04:08:35 PM »
Yep, later motors are definitely a good upgrade.  If possible get compression numbers, crank end-play & check the cam gears for pointy-ness before buying.  IIRC the gearbox is different but compatible.  The driveshaft can take up the slight difference in length.
Jorgeconrico
« Reply #10 on: September 25, 2011, 09:05:43 PM »
Hey im still around....
Im in west chester.
91E30
« Reply #11 on: September 25, 2011, 10:04:09 PM »
one of my good friends lives in west chester. im around there all the time. will be more once i get the car running.
Geoff
« Reply #12 on: September 26, 2011, 03:45:37 PM »
I'm in south jersey, 20 minutes from Philly.  Newbie also, having bought my first e-30 3 weeks ago.  I did drive an e-21 for 10 years but that doesnt count
        Regards,
        Geoff
91E30
« Reply #13 on: September 27, 2011, 08:36:38 AM »
after i get mine running id like to setup a area meet, any intrest?
colin86325
« Reply #14 on: September 27, 2011, 03:05:04 PM »
Sounds good!
