FS: 1991 318is Brilliantrot lots of work done - NJ
Author Topic: FS: 1991 318is Brilliantrot lots of work done - NJ  (Read 5845 times)
cncmastr
« on: September 06, 2011, 05:54:44 AM »
[COLOR="Red"]UPDATE - This is an old thread but has been updated as of 6/22/2013[/COLOR][/U]
Hi folks,
I am selling my baby. She is a 1991 (4/90 build) 318is with approximately 165k miles on the clock (the odo says 136,200-ish it was repaired). She was purchased in April 2010 from Texas and was registered in NYC for a few months while I was living there. I then moved to NJ and she's been registered here since. Most of the major stuff has been taken care of. This car makes a great daily driver and is in excellent mechanical shape! While this car needs cosmetic work, the mechanical stuff is in excellent shape. You will not find a car with this much work done to it, full history and records (since new), window sticker no body rush at this price. I have replaced this car with an E39 and no longer need it. Most of the recent work has been done at none other than Guten Parts (GPS) in South Orange, NJ.
PS - I believe in honesty and therefore I am laying out all the cards on the table with this car. Feel free to post or PM with any questions.
VIN: WBAAF9311MEE66430
Here or some older pictures on my flickr account.
Engine bay:
Picture as of 6/21/13 (I am in the middle of detailing)
- This fender (passenger side fender has been replaced)
- Small clear coat peeling on pass. door.
- Crack Free Dash!
- Seats are in great shape!
Pros:
  • Full vehicle history since new, including window sticker!
  • No cracks on dash! Crack free!!
  • Owned by a BMW enthusiast
  • 4.10 LSD with fluid flush (leaks a lil)
  • Brake fluid flush
  • New pedal pads
  • New Brembo solid rotors with pads
  • Coolant flush with BMW OEM fluid
  • New Bilstien Sport shocks and H&R Sport Springs
  • New Turner Motorsport “Shop” lifetime rear shock mounts
  • Replaced endlinks with stock and replaced sway bar bushings with stock
  • New M3 offset front control arm bushings
  • New front control arms
  • New rear Powerflex control arm bushings
  • New Powerflex Subframe bushings
  • VAC motorsports E30 front and rear reinforcement kit
  • Alignment
  • New exhaust rubber hanger
  • Royal purple transmission fluid flush
  • Blackstone Labs oil analysis
  • New front low beams (halogen)
  • Peerless Skid plate
  • Fuel Filter replaced
  • New battery
  • NO RUST on body – original Texas car has seen two winters
  • Stock 14” BBS basket weaves
  • New passenger side rear wheel bearing
  • Passed NY and NJ state inspection
  • New timing chain tension-er
  • New passenger side weather strip / door seal
  • All services records and receipts since new
  • Mess under the intake has been completed
  • Replaced throttle cable
  • Replaced transmission bushings
  • Replaced engine mounts
  • New T-stat
  • Replaced valve cover gaskets
  • Replaced spark plugs
  • New Steering Rack
  • Rear tailight gaskets have been replaced
  • Both rear window side sail gaskets have been replaced
  • AC has been recharged and converted - works great!
  • Odometer works
  • Shifter bushings and  selector rod have been refreshed with new OEM
Cons:
  • Clutch needs to be replaced
  • Radio works intermediately
  • Exhaust kind of touches the rear appron
  • Damage to front passenger side fender and hood corner - the fender was replaced with another
  • Drivers side door was replaced
  • Clear coat on passenger side is peeling
The price is $3500.
JP
Additional photos:
http://www.flickr.com/photos/jpalbano/sets/72157624107475285/
« Last Edit: June 25, 2013, 01:41:36 PM by cncmastr »
cncmastr
Feeler: 1991 318is Brilliantrot lots of work done
« Reply #1 on: September 07, 2011, 07:11:22 AM »
that much interest eh?
75BMW2002
« Reply #2 on: September 08, 2011, 09:17:50 AM »
Well it has only been advertised for 2 days so don't expect someone to buy it immediately plus you want them to buy it but wait a couple of weeks before they actually get the car?  Also, IMHO, I think $3500 is too much for a car that has body damage, non working AC, leaking PS and non operative odometer.   I gave less than $3000 for my last iS that needed nothing and had 134K miles.
cncmastr
« Reply #3 on: September 08, 2011, 12:53:25 PM »
I appreciate the feedback. $3500 is a good starting point for negotiation.
cncmastr
« Reply #4 on: September 13, 2011, 09:27:52 AM »
Bumpity!
Martin C.
« Reply #5 on: September 13, 2011, 09:30:00 PM »
Fix the odometer and will likely get the asking price in the open market. You will likely get less here but you'll know the car will be taken care of for long time.  GL with the sale.
cncmastr
Re: FS: 1991 318is Brilliantrot lots of work done - NJ
« Reply #6 on: June 18, 2013, 12:21:41 PM »
Bump! Back up for sale and updated!
