Author Topic: WTB: Cruise control parts to retrofit in my car  (Read 4324 times)
a930rocket
« on: September 03, 2011, 08:52:15 PM »
Title says it all.
I want to add cruise control to the car, so let me know what you have and how much sent to 29466.
Thanks,
Jim
1991 318is
1987 911 Turbo
« Reply #1 on: September 04, 2011, 08:22:39 AM »
I have a few sets, but they're not for an airbag car.  The airbag wheel controls are raked more toward the driver...my stalks won't work very well with the original airbag wheel.  I'm also missing the e36 cable and the mounting bracket.
a930rocket
« Reply #2 on: September 04, 2011, 06:56:08 PM »
I'm using a MOMO wheel (non-airbag) with a 1" spacer, so the wheel might be further back?
How far/close would the stalk be to a stock wheel?
Here's one on ebay, but it's $130 !!! http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?VISuperSize&item=140600941128
« Last Edit: September 04, 2011, 07:00:35 PM by a930rocket »
1991 318is
1987 911 Turbo
« Reply #3 on: September 05, 2011, 07:48:43 AM »
It might work, I'm honestly not sure.  I'll go take some measurements off my stock non-airbag wheel to see how far it comes off the hub.  If it doesn't fit just send it back - all you'll be out is postage.
BTW, that posting doesn't have the right actuator cable nor the mount from what I can see.
a930rocket
« Reply #4 on: September 05, 2011, 11:16:26 AM »
How much do you want for what you have?
And I'll need to get the e36 cable and the mounting bracket correct?
On the brake duct, I'll measure mine as well.
1991 318is
1987 911 Turbo
« Reply #5 on: September 05, 2011, 02:17:25 PM »
Let me collect my stuff together & PM you with some pics.
a930rocket
« Reply #6 on: September 05, 2011, 06:57:17 PM »
Sounds good. Thanks.
BTW, Here are some pictures of my steering wheel and brake duct for measurements.
« Last Edit: September 05, 2011, 07:01:21 PM by a930rocket »
1991 318is
1987 911 Turbo
« Reply #7 on: September 05, 2011, 09:40:12 PM »
The brake duct seems about the right length:
The turn signal switch seems about the same in both pics...maybe 5.5" from the dash.  I think my non-airbag switch will work.  My non-airbag wheel is about an inch closer to the dash than yours is, you'll have no problem there.  You'll just have to notch the lower steering column for the switch and punch out one of the firewall bungs for the actuator cable.
« Last Edit: September 05, 2011, 09:43:16 PM by DesktopDave »
