Author Topic: M42 Project Liquidation  (Read 6874 times)
TheNeek
« on: September 02, 2011, 07:12:46 PM »
I'm never going to get around to this.  I have too many projects as it is, this has all got to go.
If you need it, I probably have it.
Highlights:
Rebuilt cylinder head (sold)
Full Timing Set (sold) Brand new guides, pump, chain etc.
Cometic MLS Headgasket (sold)
Raceware Head Stud Kit ($125) Only opened to mock up head on block, never torqued:
Raceware main bearing stud kit ($125) Never opened, I know it says 320i, it's the same for either motor (M42 or M10).
I also have a spare block ($100):
Custom Stuff:
Beginnings of a custom intake manifold ($250).  Uses standard size tubing.  Bolts to factory mid manifold as shown.  Requires tig welding and fab of top box:
Supercharger from c230 kompressor (early model) ($150):
More photos of stuff including part numbers and more detail shots below.  The seal sets are NOT complete.  I stole some stuff from them.  Make me an offer, or a request if you need something specific.  I took apart a full M42 and stored all the parts.   I may have used some of the stuff on the M42 in my E21, but I can look through anything for you all.:
http://s193.photobucket.com/albums/z45/m42power/M42%20For%20Sale/
« Last Edit: September 18, 2011, 07:00:30 PM by TheNeek »
« Reply #1 on: September 02, 2011, 09:05:29 PM »
Good luck with the sale.  That's quite the selection of parts.  Wrong coast for me as well.
Is that a Bavaria?
TheNeek
« Reply #2 on: September 02, 2011, 09:46:51 PM »
Quote from: DesktopDave;106497
Is that a Bavaria?
Yup, not everyone's cup of tea though:
http://www.stanceworks.com/2011/08/bavacious/
« Reply #3 on: September 03, 2011, 07:41:51 AM »
Wow, you're not kidding about slamming.  Nicely kept up though.  The e3 Bav is one of my favorite BMWs.
a930rocket
« Reply #4 on: September 03, 2011, 08:55:17 PM »
Looks like lots of engine parts. Good luck!
Any cruise control parts for sale?
1991 318is
1987 911 Turbo
TheNeek
« Reply #5 on: September 05, 2011, 01:23:07 PM »
Quote from: a930rocket;106509
Sadly no, I have an M42 in my E21, not an E30 so there isn't any cruise control stuff.
Carter
« Reply #6 on: September 05, 2011, 10:32:43 PM »
That head is very tempting, let me see if any of the 4 I currently have will keep compression and  coolant in their proper areas.
Your bavaria is awesome.
TheNeek
« Reply #7 on: September 07, 2011, 11:00:29 AM »
updated  head and headgasket sold
« Last Edit: September 12, 2011, 01:29:27 PM by TheNeek »
TheStorm
« Reply #8 on: September 09, 2011, 06:01:20 AM »
interested in the gasket if still available
longms
« Reply #9 on: September 11, 2011, 10:23:01 PM »
Where are you located? would the supercharger work with the M42 motor? How much for the head and head hardware?
TheNeek
« Reply #10 on: September 12, 2011, 01:26:03 PM »
Quote from: longms;106627
the head, headgasket, and AFM are sold.
Sale pending on air box and misc vac and coolant lines.
I'm in Mill Creek Wa.
I bought the SC because I had seen an install with that charger make 200hp and it was a mild build.  As stated above the head and headgasket are sold, but the hardware is still available.
longms
« Reply #11 on: September 14, 2011, 11:54:49 AM »
Do you have a link to the thread with this supercharger mild build?
TheNeek
« Reply #12 on: September 15, 2011, 11:25:26 AM »
Quote from: longms;106669
Appletree did his before he moved to the rotrex charger.
http://www.m42club.com/forums/showthread.php?t=2372
The E30Zone now requires membership to read.
This is an M45 eaton with different ports than the one he used.  Here is a video of the M45 I have mounted in an M40.
http://www.youtube.com/watch?v=KwrhjaL9tvk
It won't support 300hp, but it's a decent sized supercharger for a 1.8l engine.
