Author Topic: Differential, Small case vs Medium?  (Read 7740 times)
TG197
« on: August 21, 2011, 11:30:52 AM »
I need to replace my Differential (small case, 4.10 open), will a medium case
(188mm) bolt right in ?. It is hard to find the small case w/ 4.10. The reason I am looking to replace the unit is that the component that the ring gear is attached to (spool?) has broken in half. However, I have disassmbled the Diff. and it would be just as well to replace the broken part if I could find one.
« Last Edit: August 21, 2011, 11:58:02 AM by TG197 »
romkasponka
« Reply #1 on: August 21, 2011, 12:59:47 PM »
Quote from: TG197;106259
Yes, it's bolt right in. Could be that you will need driveshaft lenght adjustment in the middle.
E30 318is M42
E36 318is M44
TG197
« Reply #2 on: August 21, 2011, 01:10:15 PM »
Thanks, that is good news, as there is a lot more medium case diff.'s for sale
than the small case. I want to stay with the 4.10 ratio.
Balkanac
« Reply #3 on: August 22, 2011, 03:51:24 AM »
I have a medium case 4.10 LSD off a US model e30 m3 and it bolted right in. Didnt need to touch the driveshaft. Apparently small case diffs are prone to beakage, where mediums can take a lot more
1991 BMW 318is E30 RED
« Reply #4 on: August 22, 2011, 07:25:11 AM »
Same here.  My small case 4.10 died and I replaced it with a 3.73 LSD from an '87 325is.  Bolted right in.  Like romasponka said, I had to adjust the drive shaft length slightly.
This is a good time to replace the center support bearing and guibo as well...
91 e30m42
« Reply #5 on: September 13, 2011, 06:34:06 PM »
now how do you adjust the drive shaft length slightly as im kinda interested in this mod as well.... sorry for the thread jack
romkasponka
« Reply #6 on: September 14, 2011, 02:24:18 PM »
Quote from: 91 e30m42;106659
In the middle you have big nut...
E30 318is M42
E36 318is M44
« Reply #7 on: September 14, 2011, 09:03:15 PM »
+1...there is a really large nut in the middle of the driveshaft.  It looks like a sleeve but the sheet metal is flanged out in a hex shape.  The shaft is two pieces splined together under that cap with a rubber sleeve.
Also check your tranny mounts, guibo, center support bearing and rear u-joint while you're under there.
I wire brush the splines & spray some PB Blaster to clean them out.  You can compensate an easy 2-3" for longer diffs.  If you do replace the center support bearing while you're there, it comes off the spline joint after removing a big circlip.  Be sure you pre-load the CSB forward 4-6mm when you put it back together.
91 e30m42
« Reply #8 on: September 14, 2011, 10:51:02 PM »
great dtails there dave thank you will be looking more into this...as for all my mounts and bushings they are all new so no worries in there
mtle30
« Reply #9 on: February 16, 2012, 05:47:09 PM »
I'm having this differential issue, I was lucky to get a free refurbished driveshaft from a 325, however the problem I'm having is the center Lange that bolts up to the car doesn't match with the car, and I have a 4.10 LSD medium case. The size of the driveshaft with diff is good but I can't bolt up the driveshaft, anyone have suggestions?
How exactly would I shorten my current driveshaft to fit the 4.10 LSD medium case?
« Last Edit: February 16, 2012, 06:44:51 PM by mtle30 »
Montreal-E30 :eek:
