Author Topic: Headlight Low-beam concerns  (Read 3259 times)
M42_Jester
« on: August 20, 2011, 04:50:24 AM »
Hey all,
Is there any reason in particular that the low-beam setting on the head lights would all of a sudden stop working?? i can't make any sense of it at all. the parkers work...as do the high-beams...but the low-beams just won't turn on...it's not the bulbs, as i have checked them with the high-beams...they work fine...i have also checked all the fuses and i have nothing blown...
if anyone can help me, that would be great. would be good to be able to drive at night u know...
Cheers,
Jester
monty23psk
  • -Receive: 17
« Reply #1 on: August 20, 2011, 08:02:59 AM »
how did you check them with the high beam? The low beam bulbs actually have dual filament, one for low and one for high. This means you can have a low beam not working and they turn on with you turn on the high beams.
« Reply #2 on: August 20, 2011, 09:33:56 AM »
The lights are on a relay as well.  The e36 might have a lighting control module as well, let me look into that & get back to you.
This looks promising, repairing a bad fender ground for the fix:
http://www.bimmerfest.com/forums/showthread.php?t=414472
Low beam relay:
http://www.bimmerfest.com/forums/showthread.php?t=385287
This thread notes an inline fuse that might be loose...not sure about that one:
http://forums.bimmerforums.com/forum/showthread.php?t=957724
The CCM is wired in parallel, so it can't be a cause.  Here's a fix for the "low beam failure" error message though:
http://www.emotors.ca/articles/60.aspx
« Last Edit: August 20, 2011, 09:47:23 AM by DesktopDave »
M42_Jester
« Reply #3 on: August 21, 2011, 03:38:43 AM »
Quote from: DesktopDave;106236
Low beam relay:
Cheers for this. the problem is all fixed now. I swapped relay 6 with relay 7 and everything was fine.
Thanks for all you help guys. appreciate it :)
Jester
