Author Topic: Good used diff  (Read 1828 times)
ck_carnut
    • http://home.comcast.net/~kvcbk/
Good used diff
« on: July 25, 2011, 08:32:41 PM »
Where is the best place to get a good used diff? The last 2 I've replaced seem to last only about 50K miles before they get noisy, and I'd rather not be replacing these things every 2-3 years. The current one seems to need output bearings, and I'm not sure I'm up to rebuilding it myself.
Thanks.
-=Chris
The toys:
\'91 318is
\'77 MG Midget
\'75 Cosworth Vega
The workhorses:
\'09 WRX (hers)
\'00 Ranger (parts hauler)
Good used diff
« Reply #1 on: July 26, 2011, 07:16:21 AM »
They're all a gamble, the two I've replaced were limited-slip units but they never seem to do any limiting...
I'd considered getting one rebuilt with a functional LS unit, but that gets pricey.  The parts are cheap but the services are expensive.
Good used diff
« Reply #2 on: July 26, 2011, 07:30:01 AM »
I also used a medium case diff donated from a 325is...the small case isn't as durable.  It's a straight swap, but finding something as high as a 4.10 would be difficult (I think only >88 auto 'verts had them).  I used a 3.73 and IMHO it's an improvement over the 4.10.
When I bought mine the input seal failed, ruining the input shaft bearing.  I pretty sure that grinding diff was the reason he decided to sell it.  I might have been able to rebuild it, but decided to replace it instead.
From the PO's records my car is on her third rear-end.  I'm hoping the heavier medium case lasts longer.  I pulled it from a car with 167K miles and I've put 20K on it since, no problems yet.
