Author Topic: Molded dash cover?  (Read 5982 times)
rollwaveroll
Molded dash cover?
« on: July 07, 2011, 06:09:56 PM »
I've got a lot of dashboard cracks in my newly acquired 1984 318i. Has anyone used or heard anything about the molded plastic dash covers I see available online? Or, if I choose to have the dash replaced, any estimates on about what that would cost all in? Thanks
Molded dash cover?
« Reply #1 on: July 07, 2011, 06:19:55 PM »
Those dashes tend toward $200 from what I've seen up here, but that Georgia sun is brutal.  Supply & demand keeps the prices up.  I'm not sure about the covers, I've seen a few online but not firsthand.
It's a shame you're not closer; I have one in great shape.  I'll have to update that "for sale" thread of mine...
monty23psk
  • -Receive: 17
Molded dash cover?
« Reply #2 on: July 07, 2011, 07:39:14 PM »
I have seen a molded one but with heat it starts to curl up a little, like it is shrinking. So they work, but need to be taken car off and not a lot of heat or sun.
rollwaveroll
Molded dash cover?
« Reply #3 on: July 08, 2011, 11:19:42 AM »
Thanks guys. The GA sun is pretty intense, but at the same time, mine will be garaged either at home or work over 90% of the time. I'll see if I can find a mechanic to quote me on dash replacement, and if it is too high maybe I'll try the dash cover approach.
Molded dash cover?
« Reply #4 on: July 08, 2011, 07:19:40 PM »
Hopefully your mechanic will know where the best salvage yards are.  OEM for a dash is impossibly expensive.  Try out R3v to see if anyone local has a useable part.
Make sure you update this thread with anything you discover about those covers.
92BMW318is
Molded dash cover?
« Reply #5 on: July 11, 2011, 04:20:10 PM »
I just bought a new dash for my car for 10 dollars, try places like pullapart
e30boarder
Molded dash cover?
« Reply #6 on: July 11, 2011, 04:37:20 PM »
I had a plastic cover in my '84. I would advise against it. It doesnt look the greatest. Small gaps around the air vents, etc... Maybe mine was different but it didnt look better IMO. In fact, I would have been just as happy with the cracks in the dash. Thats just my 2 cents...
a930rocket
Molded dash cover?
« Reply #7 on: July 24, 2011, 08:19:30 PM »
What about one of those carpeted covers?
My dash has no cracks and I was thinking of covering it with something to protect it..
1991 318is
1987 911 Turbo
monty23psk
  • -Receive: 17
Molded dash cover?
« Reply #8 on: July 24, 2011, 09:33:14 PM »
I would recommend a UV windshield cover for when you park, always try to park in the shade and then protect it with vinyl cleaner that keeps it oiled and doesnt dry, like armor all. I use Meguiars #40 vinyl rubber cleaner and it works for last 8 years on my 2 bmw dashes. Thats my .02. The carpet will keep it clean but not sure on fitment.
a930rocket
Molded dash cover?
« Reply #9 on: July 27, 2011, 05:42:21 PM »
I'm getting the UV film Friday.
There's a BMW hsop across the street that has an E30 for part and a molded carpet dash I might ask about. I will need some TLC to make it look good, but just might work.
1991 318is
1987 911 Turbo
lbreevesii
Molded dash cover?
« Reply #10 on: September 05, 2011, 02:53:10 PM »
I highly recommend using 303 on your dash.  I did some testing(non scientific though it was).
I picked a crack on my old dash and liberally treated one side with 303 and let it sit(note: this is not normal usage),  wiped it down later, then added more.  Repeated several times.  Afterwards I was able to easily crack the untreated side with minimal force.  The treated side I was pushing so hard i was afraid it would deform the whole area before it cracked.
303 does not advertise to put the spring back in your vinyl,  but it does!
