Author Topic: Valeo clutch kit  (Read 3323 times)
romkasponka
Valeo clutch kit
« on: July 04, 2011, 03:47:07 PM »
Just spotted BMW E36 318is M44 clutch kit with single mass flywheel, so I think it will fit E30 318is.
3276428350172
D1: 229mm; Version DBR; D2: 228.6mm; 10 teeth; spline 23.13; spline 29.13; With flywheel; With release assembly; With friction plate; With release bearing
http://www.aldocsys.net/PDF/00073/835017%20V1.PDF
Price in lithuania is ~450Eu.
E30 318is M42
E36 318is M44
PumpItUp
Valeo clutch kit
« Reply #1 on: July 04, 2011, 10:37:28 PM »
but my newly installed used m20 starter sounds cooler than my old m42 starter!
another bonus to consider when doing m20 flywheel conversion  :)
Valeo clutch kit
« Reply #2 on: July 05, 2011, 07:29:49 AM »
I'm temped by both solutions...but the Valeo is much more expensive here (~$800 USD).  It'll be tough to decide once the clutch goes...
audiphile
Valeo clutch kit
« Reply #3 on: February 11, 2013, 07:14:15 AM »
http://www.amazon.com/Valeo-52161203-Solid-Flywheel-Conversion/dp/B001DHC3V8
I hear they don't last long. I installed one on a e46 323i I had a long time ago (even though it's not listed as compatible, it worked perfectly). I didn't have the car long enough to know if the durability issue is true.
audiphile
Valeo clutch kit
« Reply #4 on: February 11, 2013, 07:14:48 AM »
