If it wiggles at all, you have a problem. You can't even check if it is correctly timed because the vibration dampener may not be in the correct spot.
Pull the belts, take the 6 bolts out of the pulley and remove it and the vibration dampener. That should leave you with just the hub. Unscrew the big crankshaft bolt and try to pull the hub off and see what you have. Hopefully the keyway and hub are not chewed up too badly.
Here is where you may want to stop and take a breath. If in fact this hub has slipped and spun on the crank, your timing is going to be off. Unfortunately, this is what is called an "interference" engine, which means that it is possible for the valves to come into contact with the pistons. Depending on how much you have cranked this thing, it is possible that you could have bent valves or damaged pistons. This is the worst case scenario though. Since the engine hasn't actually "run" odds are that even if a valve contacted a piston, it wasn't hard enough to bend it. If it put a dent in the piston, a "hotspot" could develop on the piston which would lead to premature failure down the road.
Let's think positive though! Hopefully you can reseat the hub onto the keyway, put it back together and check the timing. The flatspot on the outer rim of the vibration dampener should line up with the arrow on the Oil filter housing. If that is good and it's all securely bolted down, fire that baby back up.
