Alex,
..if you the spot weld tool pictured, it may create a pilot hole to get the bit centered. unless there is already a small hole that's covered up. Check to see if there is a spot weld bit without that 'thin pointer' in the middle, then you will be able to remove the spot weld, and get the bracket off cleanly.
