DIY- E36 Reset Oil - Service Lights after Oil Change
Author Topic: DIY- E36 Reset Oil - Service Lights after Oil Change  (Read 7441 times)
sqlpython
« on: June 15, 2011, 03:45:07 PM »
I did a search and did not come up with this simple How To on the Forum.
So, I found the solution on the BMW Blog
http://www.bmwe36blog.com/tag/reset-bmw-e36-oil-service-light/
Quote
Reset BMW E36 oil service light
After changing the oil for your car, the oil service light stays on (on the red) and it becomes very annoying to you sometimes. It makes me upset just to see it like that, so I wanted to find out how this creature is reset. It turned out that the procedure is very simple and it doesn’t need time, money or even special equipment. Well, only a paperclip ;-). The following article will show you how this thing is done within couple minutes. BTW, I didn’t write this article. I found it here in case you want to read it. Ready? ok here we go . . .
 Disclaimer: Use this procedure at your own risk!! I’m not responsible for your mistakes man! :D
    First, pop your hood and find the diagnostic data port. It is located on the right side of the engine bay near the right strut tower.
    Unscrew the cap. You will see a big Pac-Man shaped hole and twenty little round holes. What is a Pac-Man? Never mind. We are only concerned with pin 7 and pin 19 (note: the words "pin" and "hole" are used interchangeably in this text). Refer to the picture below to find pins 7 and 19.
    What we will be doing in this exercise is connecting pins 7 and 19 with a paperclip for four seconds. This will reset the oil service light. Simple, no? But first, here is the list of pins and what they are supposed to do:
    Pin    Terminal    Description
    1    TD    TD Signal
    2    -    Not occupied
    3    -    Not occupied
    4    -    Not occupied
    5    -    Not occupied
    6    -    Not occupied
    7    SI    Service Interval Reset
    8    -    Not occupied
    9    -    Not occupied
    10    -    Not occupied
    11    -    Not occupied
    12    61 (D+)    Generator Charge Indicator
    13    -    Not occupied
    14    30    Voltage; Hot At All Times
    15    RXD    Diagnostic Data Link
    16    15S    Voltage; Ignition Switch in Run
    17    -    Not occupied
    18    PGSP    Programming Line
    19    31    Ground
    20    TXD    Diagnostic Data Link
    OK, using a paperclip, Bend your paperclip it so it looks like this:
    Well it doesn’t have to look exactly like this, but you get the idea. Use pliers if you have to. We want those little loops at the end to maximize the contact with the conductors in the holes of the data port. If you can’t make those little loops at the ends, that’s okay. Just don’t go running around with sharp objects.
    OK, now you’re ready to reset the oil service light, so turn the ignition key to position II, but don’t start the car. Get out of the car and go to the data port. Always connect pin 7 first. Once you’ve inserted one end into pin 7, insert the other end into pin 19 and hold it there for 4 seconds. Then remove the paperclip. Check the dash and the oil inspection lights should be reset. The reset occurs upon removal of the clip.
    IMPORTANT: DO NOT HOLD IT THERE FOR LONGER THAN 10 SECONDS
or you may inadvertently reset your inspection I/II interval.
    OK, you’re done. It was pretty easy as I promised! wasn’t it?
`93 E36 BMW 318i sedan
carlos318is
« Reply #1 on: June 15, 2011, 05:15:45 PM »
Will this work for the E30 318is
sqlpython
« Reply #2 on: June 15, 2011, 10:28:02 PM »
Well, who here knows E30s any better then DesktopDave and this is what he posted..
Yes...... http://www.m42club.com/forums/showthread.php?t=13659
carlos318is
« Reply #3 on: June 17, 2011, 12:56:17 PM »
Thanks mate :D
e30bmart
« Reply #4 on: July 01, 2011, 09:51:19 AM »
yep works for the 318is.. I allways find these diy after I take the "risk" to try it for myself..
